That will keep you young.Thanks man, 45 years young.
Amongst other things, a keen cyclist - takes 9 tubes to fabricate a bike frame.
Dan
I'm back out surfing at 71 and going for 9+ more tubes.
DaBull
Dan
Love that karmann ghia! Please look after the roofPlanning:
After cutting the grille I felt like the "plastic was off". At the time i couldn't find any info with regard to how and where to run electrical wires for UHF ratio and electric trailer brakes, compressor placement etc, so i set to stripping the car to have a good look around and start planning.
i stripped the back door trims and the cargo areas, removed the battery covers from the rear seat, removed the front seats and carpet under them. Then took the dash apart, removed the centre console and roof switch panel. wheel inner guards came out along with the wheel arch flares and the external trims around the back door. Learnt plenty and didn't break much.
I found all the spare aux wiring - what an easter egg hunt that was!
Then set to testing a bunch of things to see how they worked and what voltage things ran at.
Also sketched out the aux switch panel as people kept asking me what was what up there - ref the photos below
Rear muffler removal:
I was pretty keen to start looking at making a second fuel tank, most obvious spot i could see was where the rear muffler lives. So to get the ball rolling a friend removed the rear muffler and straight piped it.
No it doesn't sound any different. Honestly not the slightest bit either inside the car or with your ear next to the tail pipe.
No idea why it's there, maybe for the petrol and it gets left in for the diesel. i don't know.
Anyway, i havent had a chance to get onto the tank yet, but there is room for a good 50L by my measurements. Shouldn't be too hard to tee into the filler hose either. then the plan will be an electric transfer pump to pump into the main tank.
I echo the others - thanks for recording your mods.Rock sliders / Side steps:
I had the car delivered with factory sliders in the hope they could be used for side steps too. They can’t.
So I cut them off the mounts and moved them. They went up and out about 50mm, and rotated downward a bit too. They now roughly line up with the tyres when viewed from above. This is better for getting in and out of the car, plus now they sit outside the bodywork they’ll protect it from being doored in car parks etc.
I now need to pull them off and re-powdercoat them.
Hi Logsplitter, I’d like to get this done on my Petrol TM in UK. If you find anyone willing to give it a go on ours, please let me know!Sounds good to me if I can get another 80L plus under there. Will save carrying extra fuel in Jerry cans. I’ve just had confirmed by a friend in the know that this will not affect the MOT in the U.K. as long as the sound of the exhaust isn’t noticeable louder.
Will do. I’ve got some feelers out. Myself or my Grenadier won’t be back in the U.K. for a while. But no rush it’s good to watch the forum and seeing what others are doing and which fabricator is doing whatHi Logsplitter, I’d like to get this done on my Petrol TM in UK. If you find anyone willing to give it a go on ours, please let me know!
Hi ninetubes, I used to have a Karmann Ghia that was almost identical to yours. I painted mine Porsche "Ice Green". That color made it go faster. DaBullIt’s my wife’s. I did 5 months in that as a daily in the final run up to the grenny.
We have since sold if to make way for the camper. Losing that, the landy, and an rs4 I the last 12 months feels like something that I’ll talk about a lot in the future
That was over 50 years ago, did they have camera's back then. DaBullPhoto or it didn’t happen
Good to know. I’m a bit of a towing sceptic but for Gary Junction Road/Tanami etc it’s clearly the way to go. X1 in particular looks very nicely engineered.10/10! I’d done all my maintenance and a few mods like lithium before we left so no dramas (except a minor adjustment of a new set of brakes I over adjusted)
I friend had an X1 for a good 5 years. After seeing where that got to, the abuse it got and the way it kept coming back for more, I didn’t even look at anything else.
Hi Nine Tubes, thank you very much from Germany for the excellent documentation of your improvements! That`s a great help for many people all over the world!Rock Lights:
I found a bunch of rock lights amongst my stuff. A set of 6 coloured ones, and a pair of white ones.
I think they were given to me so I do t have a link, but similar to these Stedi ones
I didn’t really aspire to having these on the car, but given I had them I thought they could make for good ambient camp lights. Nothing too obnoxious, just enough indirect light to stop you from tripping over something.
The six seemed over the top, so I fitted 2 to the car. I mounted them on the rear facing part of the front rock slider mounting bracket. So just behind the front wheel. They are well protected there and cast a light to the sides and out the rear of the car (for when you approach the rear).
To wire them up I took the 10A under bonnet aux power (EXT 1) and ran that under the car. For the LHS light, I pushed the wire inside the cross member to keep it neat and protected.
The 6 coloured ones went on the camper, which is kind of neat as they can be controlled by your phone or music etc. which mezmarises my 3yo daughter.
View attachment 7839933View attachment 7839934
Nice Work!! Could you tell me where you found the Ext 1 (10amp) wires? I found the Ext 5 location, but can't find Ext1. Thanks!Rock Lights:
EXT1 on my RHD was nearby EXT5, on the lower side of the loom. Had to remove the airbox lid to get a hold of it.Nice Work!! Could you tell me where you found the Ext 1 (10amp) wires? I found the Ext 5 location, but can't find Ext1. Thanks!
Thank you!Here are both the 25A and the 10A pairs. The rearmost one is the 10A. Look for the shiny PVC tape on the wiring harness behind the airbox
Hey Hans,
Thanks mate.
1. The sliders are just far enough out to get a boot on. Ergonomically they are a bit too high to enter and exit comfortably. The trade off to maintaining good ground clearance.
2. I find the 2.5m long roof rack adequate. Enough room for a 2.1m roof tent plus jerrycans etc.
3. The muffler makes no difference at all. Even under load at high revs. I have seen it removed from a petrol and it made a big difference. I believe it’s mainly for the petrol and has just been left in the diesel which doesn’t really need it due to having 2 turbos a cat and a dpf to attenuate the exhaust noise.
All the best, Dan
