Maybe new aspect regarding HVAC problems
Quartermaster
Quartermaster Owner
11:48 PM
Hi all,
overall, the air conditioning in my Quatermaster Diesel worked quite well, apart from a few temperature fluctuations over the first 5,000 kilometres.
Yesterday, however, we were driving with five people and four of us were too hot at 19°C selected and I had a strong, cold draught on my legs at higher car speeds on the front passenger seat. Back at home I looked for the cause and probably found it: there is a combined swichting flap/ channel for the recirculating underneath / behind the glove box, which seemed not to be tight when in non-recirculating position so cold air from outside was pushed into the footwell at higher speeds (in recirculating position, the port from outside is closed and the air is sucked out of the footwell, in the other position a channel is turned between outside port and heating system, all sealed by rubber lips).
The next problem might be, that the sensor for inside air temperature is located just over the glove box (at least i think the inlet for the sensor is there), so in that area were it was to cold at speed. Which lets the heating heat more and more.
At least in auto position, the recirculating flap is closed when the car is shut off and switches when driving. So the non-sealed condition could occur occasionally, from drive to drive different. Maybe it is worth to be checked by those having problems. I pushed the flap back a little and it was fine after that, but i have to check a little more with a passenger...
Would you post some pics next time your back there, for those of us that haven’t explored that far?
Don´t get me wrong, i did not dismount anything for it. You can just see it from the footwell upwards. With the ignition on, press the recirculation button, and you can see, what happens.
Picture shows recirculation position. Air is sucked through the gutter.
Oh great! Now I have to look at my Quartermaster, as I think I ran the cable tie that supports my UHF through the mesh in front of the flap. Probably also over the filter. One of the problems of being 62, with a bad back. Things get done by feel rather than visualizing where things are going.😁
To address your post, do you recommend using the recirc function or have it off? Does just cycling the button correct the flap position?
Cheers,
Ken
The recirculating function can only be used temporarily. It should disable itself after a certain period of time for passengers not getting conscious because of lacking of O2.
My post was just an idea, if a leaking fresh air channel can cause problems with holding the temperature.
Cycling the flap / channel could help indeed.
Thanks for the reply. I have not had this issue, but I only have just over 1000k's on my truck. Because I live in the tropics, I will notice if the flap is open and allowing outside air to override the air con. If it happens will cycle recirc button and see if it closes the flap.
Cheers for the heads up..
