So it seems like quite a few people have had a spare key blade cut which can open the doors. I have had this done by a locksmith using a SILKA VA2TE key blank (
https://www.lsc.com.au/silca-blank-va-2-te-trans-empty-l-chip).
That key does not have a transponder so I can unlock the door and turn the key in the ignition but the engine will not start.
Then I started looking at ways to "clone" the transponder. Apparently in some cases it is possible to use a device to "read" the transponder info from the genuine Ineos key and program that to a new transponder chip. I bought this device to give it a go (
https://www.xhorsevvdi.com/wholesale/vvdi-mini-lite.html)
This is what I get when I read the transponder in my key
I think "locked/uncloneable" means that you can't do a direct copy of the transponder info - at least not with the tool I have. I suspect that you can only clone older/less secure transponder chips.
I believe the other option is to buy a new 4A/ID4A compatible transponder chip, put it in the key and then program that transponder to be able to start the vehicle - which I assume can only be done using the dealer diagnostic tools to program the car to recognise that new transponder.
When I try the same tool on our other car key (Ford Escape) that has a "49" transponder which is also "uncloneable" :-(
So my question - does anyone have a replacement key which can start the car?
and if so did the Ineos dealer have to work some magic to make it work?
or has a automotive locksmith been able to do it?
