Local Forum Guidelines D-A-CH (Lokale Forums-Leitlinien D-A-CH)
Status
Not open for further replies.
Stu_Barnes
Fixer & General Dogsbody
8:50 PM
Los Angeles
Deutsche Übersetzuung weiter unten im Beitrag.
Welcome to the German language region D-A-CH forum,
This section of the INEOS forum is for particular conversations concerning D-A-CH. A few examples of what lives here as opposed to elsewhere on the forum.
  • Fuel station prices in a particular town / village.
  • Fuel availability in sparsely populated or lonesome areas
  • Recommendations on coffee bars, restaurants, pubs in a particular town / village.
  • Conversations about and arranging local meetups.
  • Conversation about local trails and routes. Although if you put together a trail/route report with photos and GPX files etc then please put this report in the Off-road, Overlanding, Green Laning & Equipment section.
  • Recommended overnight accommodations, campsites, and permitted fireplaces, if applicable.
  • Official regulations, insurance conditions, legality issues
  • Informations about emergency support.
Anyone registered on the forum can comment or start a thread, but if it has no particular reference to D-A-CH then it will be deleted or moved to the relevant portion of the forum. Technical fixes or conversations more appropriate for the wider global community will be moved accordingly.
You can use your native language for this section of the forum.
The code of conduct applies here as elsewhere on the site, if you need a refresher then please read Forum Guidelines (please read).
Tags, please use at least 2 tags for threads that you start, D-A-CH being one then the others particular to the thread itself, these auto populate to some degree when you create a thread. This helps to categorize things and in future will be invaluable for cross referencing.
@emax has volunteered to run and moderate this portion of the forum, please don't waste his time by reckless behavior or attitude, I'm sure that won't happen but I had to say it.
Stu.
Willkommen im D-A-CH-Forum der deutschen Sprachregion
Dieser Bereich des INEOS-Forums ist für spezielle Unterhaltungen über die Region D-A-CH gedacht. Ein paar Beispiele dafür, was sich hier im Gegensatz zu anderen Bereichen des Forums abspielt:
  • Tankstellenpreise in einem bestimmten Ort
  • Verfügbarkeit von Treibstoff in dünn besiedelten Gebieten
  • Empfehlungen für Cafés, Restaurants, Pubs in einem betimmten Ort
  • Gespräche über lokale Treffen und deren Organisation.
  • Gespräche über lokale Offroad Strecken und Routen. Wenn Ihr einen Trail-/Routenbericht mit Fotos und GPX-Dateien usw. zusammenstellt, dann stellt diese bitte in den Bereich Offroad, Overlanding, Green Laning & Ausrüstung ein.
  • Empfehlenswerte Übernachtungsmöglichkeiten, Campingplätze und ggf. auch erlaubte Feuerstellen.
  • Behördliche Bestimmungen, Versicherungskonditioen, Legalitätsfragen
  • Informationen über Unterstützung in Notfällen.
Jeder, der im Forum registriert ist, kann einen Kommentar abgeben oder ein Thema eröffnen, aber wenn es keinen besonderen Bezug zu D-A-CH hat, wird das gelöscht oder in den entsprechenden Teil des Forums verschoben. Technische Korrekturen oder Unterhaltungen, die eher für die breitere globale Gemeinschaft geeignet sind, werden entsprechend verschoben.
Ihr könnt in diesem Teil des Forums Eure Muttersprache verwenden.
Der Verhaltenskodex gilt hier wie auch anderswo auf der Website. Wenn Ihr eine Auffrischung benötigt, lest bitte die Forumsrichtlinien (bitte lesen).
Tags: Bitte verwendet mindestens zwei Tags für Themen, die Ihr beginnt, wobei D-A-CH eines ist und alle weiteren speziell für das Thema selbst. Tags werden bis zu einem gewissen Grad automatisch eingefügt, wenn Ihr ein Thema erstellt. Dies hilft bei der Kategorisierung von Dingen und wird in Zukunft für Querverweise von unschätzbarem Wert sein.
@emax hat sich freiwillig bereit erklärt, diesen Teil des Forums zu leiten und zu moderieren. Bitte vergeudet seine Zeit nicht durch rücksichtsloses Verhalten oder rücksichtslose Einstellung. Ich bin sicher, das wird nicht passieren, aber ich musste es sagen.
Stu.
Status
