Leisure Battery Install
IneosGrenadierTech
INEOS Agent/Dealer (verified)
2:05 PM
Carlisle, UK
Hi all,
I was asked to design and build a completely custom leisure battery system, including split charging and multiple auxiliary outputs to support a range of devices—from Starlink satellite systems to basic USB phone chargers. All components were hand-selected by the customer to balance reliability, efficiency, and expandability.
This was actually my first project of this kind, and I built it from the ground up with future installations in mind. The system’s modular design means it can be easily adapted or scaled for future custom builds.
One of the key goals was future-proofing the setup. The system was designed with easy integration points for solar power—so adding panels down the line is as simple as plug-and-play. Whether for trickle charging or full off-grid capability, the groundwork is already there.
The project involved careful load analysis, planning for upgrades, and ensuring everything could run safely and independently of the vehicle’s main power system. From fusing and cable sizing to the mounting hardware and monitoring systems, every detail was tailored to meet the user’s unique needs.
Hi all,
A very clean install. Well thought out.
Hi all,
The led battery monitor..is it specified for Li batteries or lead acid? I suggest that a smart shunt which " counts coulombs" going in/out is the better way to monitor battery charge/discharge due to the Lithium battery's much flatter voltage-discharge curve.
Absolutely Correct... On NL's instruction sheet it states for "two lead-acid batteries".... An LED monitor showcasing voltage alone isn't going to be very helpful with a LiFePO4 battery unfortunately as they maintain very flat voltage curves until depleted
There's no voltage sensing circuit in the world that will detect or display Li battery capacity with any meaningful levels of accuracy. Would have been better off using a smart LiFePO4 battery with built-in Bluetooth and shunt and simplify the install. I'm an EE by education and trade if you need any assistance.
The battery fitted does come with Bluetooth monitoring @IneosGrenadierTech kindly sent me a link for it
Is there an actual battery to battery charger with adjustable charge voltage or is it just a solenoid relay? The manufacturer website insinuated it's a relay controller which would be horrible on several fronts....
???? I'm clueless on all this, which is why I was asking IneosGrenadierTech for help.
