Jumpstart Post
6:33 PM
Pasadena, CA, USA
Has anyone used the jumpstart post in the engine bay as a source of power for something like a winch? It appears to use a heavy gauge wire which I would think is sufficient to power a winch.
It's a high amp lug but I cannot recall if it was winch capable. DR Roks manual may help.
When I figure out my winch mounting solution then I’ll give it a try and see if anything burns up :-). At the moment there isn’t a winch solution that I like that I am willing to pay for. The “Grenadier Tax” real but will likely come down over the next year or so. I lived through the same thing when the new bronco came out.
I have the high output wiring. It has a winch power tap behind the passengers side headlight. I'm sure it connects to the jumpstart taps. I know that gp factor knows how this is wired, I talked to him about it a few months ago. I'm waiting for his winch solution to ship to me.
He researched how to install a winch without the high load output wiring installed.
I’m guessing that this is the GP Factor solution that you are waiting on.
It is certainly well thought out but damn that is expensive. I’m hoping for something similar that will accept a standard 12,000 pound winch. I don’t mind if it sticks out the top.
I don't find a lot of less expensive options yet on the market. I like the hidden winch myself.
Positive does indeed connect to the jumpstart box…….at least on RHD cars
I'm using an extra lug in the jumper box for my winch, no ill effects as of yet. It is very substantially sized
