Build Thread @Jean Mercier Build thread
Jean Mercier
GG#920
7:03 PM
Sint-Martens-Latem, Belgium
When I travel, I like to hide my luggage, even if it isn’t very valuable (tent, clothes, beer, etc.)
That's why I have optioned the tinted privacy glass. But I want a trunk cover. I decided to build a temporary one myself.
My prerequisites:
  • cheap
  • light
  • fast to build because I will travel soon to Hungary to visit my relatives.
  • No structural damage to the car for the time being
  • Therefore, using the hooks of the rear seat and …
  • The holes of the ventilation grid in the back (or how do you call these?)
I bought shade cloth (2m X 1m) and fixation rings (bag of 20, less would have been better). Total cost: 12 euro! I had also some piece of thick grey plastic, a little bit flexible and not brittle at all (see the picture).
I found also some nice metallic hooks in one of my boxes (don’t know the cost) and a plastic handle of a cardboard box. Both entered in the slits of the ventilation grid.
I played around with these and the fixation rings of the shade cloth.
Finally, I decided not to use the “modified plastic handle” but the metallic hooks alone:
07
And I saw the grey plastic in a particular shape and made some holes, see the final result below:
The final version had the next dimensions, the long hole fits exactly in the metallic hooks of the rear seat. The dimension of the other round hole depends on the screw you have (didn’t buy it, already had it).
OK, forum rules don't allow me to post more pictures in one post, therefore, I'll try to open a second one ...
Playing around with the “shade cloth” and the fixation rings is a little bit trial and error
Why did I make the cloth longer than the trunk (and wider): because I can then bend it over the edge and hid a bit better my luggage. Especially in the rear this is important as I couldn’t find a trick to bring it closer to my rear doors!
The final dimensions are to be seen in the next picture where:
  • The two rings at 5 cm distance are meant to be able to bend the cloth backward and put the hook trough the two central holes of the fixation rings.
  • The rings that I crossed out were a first attempt that I discarded.
Finally, I sewed (by hand) a hem in the cloth using the loose plastic wires that fell off the cloth and did put in each corner a supplementary fixation ring. Perhaps I can use the cloth as a sun roof outside the car.
14
Conclusion
  • The cloth isn’t stiff enough
  • It doesn’t reach the doors in the back
  • It is ugly …
  • but very cheap
  • It took some hours to build it
  • I am quite happy with plastic fixation part for the hooks of the back seat, works well
  • I have already some other ideas …
I hope some real nice aftermarket trunk cover will be available soon.
Any ideas for improving this are welcome.
Nice effort , a step above what is termed a "ghetto fix" 😁
You could also use a sheet of goatskin to pervade the interior with a nice fragrance.
Not quite black sheep, but hey...
My prerequisites:
  • cheap
  • light
View attachment 7811704View attachment 7811705
View attachment 7811708View attachment 781170907
View attachment 7811712View attachment 7811713View attachment 7811717
Here's an off the shelf trunk cover that will hide your junk.
Yes and a smelly old male goat skin that has been pissing all over his belly as they do. The smell would than put off any onlookers from peering through the window to look at any contents 😂
The goat didn't realise he was contributing to his own demise. One way to get a tan I suppose...
View attachment 7811718View attachment 7811719View attachment 7811720
Conclusion
  • It is ugly …
  • but very cheap
Great effort JM.
Why not just throw a large blanket over what ever you have in the back?
Take note gentle readers ...
this is what you (may) get when you take the time and make the effort to post up mods you think may be of interest to the community. SMFH.
For shame, peanut gallery !
JM, well done.
Well said the nice Canadian @painter and shame on you ratty Australians. Have some respect. 🤪
And @Tazzieman clearly @DaveB ’s trunks are for growers not showers. 😉
And good simple workaround @Jean Mercier. Are the 4 luggage rings all level? If so I’m wondering if for a more permanent solution you could use a sturdier material for the blind and affix occy strap (bungy cord, not sure what Europeans call it) type loops on each corner with a plastuc hook to just clip to each ring?
Conclusion
  • It is ugly …
  • but very cheap
https://www.ebay.com.au/b/Industrial-Shock-Cords-Bungees/109492/bn_78216982
bigleonski beat me to it...good minds think alike​
  • Bungee cord would help with the tensioning of the material you are using...I personally would not be drilling into the vehicle unless it is absolutely necessary...the brackets that you made are a good starting point
  • STAYPUT Bungee Shock Cord Clip extras if need 3 sizes Knobs, Pulls, & Screws
    STAYPUT Bungee Shock Cord Clip "extras if need" 3 sizes Knobs, Pulls, & Screws​
Conclusion
  • It is ugly …
  • but very cheap
The jean mercier grenadier accessory shop is now open, online orders now taken
Conclusion
  • It is ugly …
  • but very cheap
fantastic Jean 👍💪
