Ineos Grenadier Rooftop Power Adapter Cable – DTP to IP65 Waterproof Connector (AWG16), 17"
DVA Mechanics
Supporting Vendor
7:21 AM
Atlanta, GA, USA
Unlock the full potential of your Ineos Grenadier’s rooftop power ports with this AWG16 Power Adapter Cable, designed for seamless accessory integration. Featuring a Durable DTP Connector on one end and a waterproof IP65-rated connector on the other, this cable allows you to easily connect external accessories like light bars, work lights, antennas, and other rooftop gear—even those with fragile wiring as small as AWG24.
Why You Need This Cable:
Crimping fragile AWG24 wires directly to a DTP connector is challenging and unreliable. This cable provides a robust, plug-and-play solution that lets you connect accessories with wire pigtails ranging from AWG16 to AWG24 without the hassle of custom crimping or splicing.
Key Features:
✅ Purpose-Built for the Ineos Grenadier – Directly connects to the vehicle’s rooftop power DTP connector
✅ IP65 Waterproof Connector – Ensures a secure, weatherproof connection for external accessories
✅ Versatile Compatibility – Supports accessories with AWG16 to AWG24 wire pigtails
✅ Plug & Play Design – No crimping required, making installation quick and hassle-free
✅ High-Quality AWG16 Wiring – Durable and capable of handling significant power loads
✅ Flexible Use Cases – Ideal for light bars, auxiliary lighting, radio equipment, and more
This flexible, rugged adapter is the easiest way to power up your rooftop-mounted accessories without compromising reliability. Whether you’re outfitting your off-road rig for adventure or setting up a work vehicle, this cable delivers the connectivity and durability you need.
