- Local time
- 7:55 PM
- Joined
- Mar 18, 2022
- Messages
- 7,508
- Reaction score
- 15,299
- Location
- Toogoom, Fraser Coast Queensland
$2.13 a litreWhat is "Super Diesel" ??? View attachment 7878519
It can mean anything. Only diesel has a standard in Australia. It probably means it has more additives.What is "Super Diesel" ??? View attachment 7878519
I prefer "truck Diesel" makes my Grenadier feel more manlyWhat is "Super Diesel" ??? View attachment 7878519
It looks a bit like a she-weeNicely done. Every item of camping and 4WD gear should have at least two purposes. That funnel should come in handy in your RTT at night.
I have the same. Bought it off eBay as dealer said out of stock.Thanks for the reminder @bakepl.
I had tried to obtain this genuine VDub adaptor a couple of times but it was always out of stock. Currently available from Amazon. Cost me A$36.69. Delivered in 12 days ex-USA.
Length 135mm
Filler end OD 25mm (bottom)
Nozzle end ID 42mm (top)
Nozzle recess depth 25mm
Haven't used it yet. I expect it will take some trigger whispering to refuel without blow back or nozzle cut-off.
Reminder: You only need a solution like this if you're refuelling a diesel Grenadier from a hi-flow pump that is fitted with a large diameter nozzle, as is often found at truck fuel stops in Australia.
