Build Thread Igor - Build starting
That's a fairly senior charger you have there @Mudnut. Don't see many made like that anymore. Does it let you manually set the volts and amps for LiFePo4?
It is actually a friends charger, who does off grid solar on cattle stations. Dialing in the Voltage is a bit trickier than with a digital. Have the cells wired to parallel, so only putting in 3.65V, and around 8A through it. Just want to charge and top ballance. Once close, will use my Redarc charger in the Hybrid caravan to bring up to 14.4V. The charger weighs as much as the battery!
Those cells look good - what BMS are you going to use?
The EEL battery box comes with a JK200Ah BMS, and all the wires to top balance, connectors, and buss bars. Was $370 AU, but really top quality piece of kit. They come in 2 sizes. Smaller up to 230Ah cells, and this one up to 330Ah cells.
Muller Energy out of Sydney also offers some of these DIY kits. Or battery boxes with a 10 year warranty.
They even offer a DYI battery making class from time to time.
