That would be another IA **** up, I’ve been reliably informed is white for go.I wonder if IA are trying to organise grey smoke to come from the Vatican chimmey to mark the launch?
Yep, my **** up, it should be white, can't blame IA for my mistake, delays yes, but not my errorThat would be another IA **** up, I’ve been reliably informed is white for go.
Very interesting. ThanksI'd like to think that any delay, especially if software related, has to do with how the use of the axle diff locks is tied in to each other and with the use of centre diff and low range.
Ineos seem to have designed in a series of single point failures with making various operations wholly reliant on software. Absolutely bizarre when you think back to all the statements about removing complexity, back to basics functionality and analogue simplicity.
The issues were illustrated with the Scottish reviews, both in the apparent confusion of some journos as to whether the axle locks were in or not and the HDC not being able to function until other systems/sensors confirmed diff locks were disengaged.
It seems to be a software house of cards in terms of the logic tree they have constructed.
The front diff will not lock with knowing the rear diff has been locked first, so, if you have a fault with the rear diff lock (or just the i/o signal to/from a sensor) then you also loose the use of a perfectly good front diff lock.
Loose the use of either the centre diff lock or the low range (or just the i/o signal to/from a sensor) and you then loose use of both axle diff locks.
It seems the complete opposite of building in redundancy in systems.
Yes there's the argument about why use a front locker before a rear or even before the centre diff but better to apply that as a driver input and retain the ability to override it if circumstances dictate it.
It all rather reminds me of the ASPW comments when taking out his ABS/wheel speed sensor and what a similar fault would do to a new Defender.
He then said that the main drivers of the "make & batch" delays have been IA requesting some part suppliers to make minor but necessary changes.
These changes have been requested post 17 October commencement of series production to ensure necessary levels of build quality.
Considering the EU is only getting vehicles now, end of March is a reasonable time line. I waited 6 weeks after my Toyota was built for it to land, let alone clear customs/dealer delivery time went to 2 weeks after. Time will tell.....This is becoming more apparent I think - i.e. that there's physical modifications to built cars required - as the extent of the delay is being revealed. Especially if tooling was/is affected... followed by QC/re-manufacture/distribute/fit parts, etc. And so it goes on...
To hear end of March is disappointing.... I think this forum might implode
because "retro fitted locally" either impossible or very undesirableI wonder what it is and why it can't be retro fitted locally.
The legal consequences for knowingly releasing a defective vehicle are enormous.I wonder what it is and why it can't be retro fitted locally.
Unless there was a good initial batch.None of that makes sense when vehicles are leaving the factory and turning up at agents?
Unless the ‘Hard Way Home’ participants are to receive their vehicles before dealers release?None of that makes sense when vehicles are leaving the factory and turning up at agents?
Unless it was a really really hard way home and they are all lost, sitting on the side of the track and crying like people who identify as little girlsUnless the ‘Hard Way Home’ participants are to receive their vehicles before dealers release?
batches of components are being continuously delivered by suppliers to the assembly line on a "just in time" basis. Arrival timing slots are critical for a moving assembly line. It's quite possible that several batches of "whatever" arrived which were faulty.... now the faulty components have to be rectified... so those vehicles are "quarantined" and until the IA Quality assurance personnel are satisfied, then they have to resort to "batch and hold" ...None of that makes sense when vehicles are leaving the factory and turning up at agents?
Yeah, sounds like there’s some rework going onbatches of components are being continuously delivered by suppliers to the assembly line on a "just in time" basis. Arrival timing slots are critical for a moving assembly line. It's quite possible that several batches of "whatever" arrived which were faulty.... now the faulty components have to be rectified... so those vehicles are "quarantined" and until the IA Quality assurance personnel are satisfied, then they have to resort to "batch and hold" ...
I understand all that, my post was in relation to #127, 128 & 129.batches of components are being continuously delivered by suppliers to the assembly line on a "just in time" basis. Arrival timing slots are critical for a moving assembly line. It's quite possible that several batches of "whatever" arrived which were faulty.... now the faulty components have to be rectified... so those vehicles are "quarantined" and until the IA Quality assurance personnel are satisfied, then they have to resort to "batch and hold" ...
At least no one from the forum.So, no consumer has had had their IG delivered?
There are customer cars, mine included, that have been sitting at the dealer for two weeks. Just waiting for the mythical software update…. Highly frustrating.So, no consumer has had had their IG delivered?
