Ideas on drawer systems
Aluminium locking drawer with pull out bench. The main slides are rated at 227kg. The unit weighs in just under 40kg including the Grenadier L Track rails fitted. I had to space between the chassis and the underside of the module. I like that the drawer is a useful depth and both bench and drawer lock in the outward position.
Similar Dunn and Watson set up.. instead of bench ordered the cutlery drawer with lid... takes up same space as bench. Installed yesterday arv and off to Victoria for a trip tomorrow. Will consider installing top/wings on return but weight is an issue - hence single large drawer rather than two.
That pull out cutlery drawer is a great idea. You get a bench and a place for low storage under it.
and was manufactured/delivered far quicker than the camp table that was ordered yonks ago with the car and still no sign of it despite asking and asking and... perhaps I don't need it now with this drawer and I'll accept a refund ;)
Interesting to see how Scott Brady has got Front Runner to sort a system for him:
Does anyone knows if there's an identical product available in europe or if FR will produce it in the near future ? Seems like the perfect rig for my use, light and no nonsense
Upgrade to my set up.
- Aluminium edge on the main right section to stop stuff sliding out.
- Drop in shelf (4 screws and t nuts to hold it in place) for when the fridge isn't in the car. Also aluminium edged.
- slide is still usable if I decide to mount a box for another drawer.
- I now gain a level platform for the dogs (interlocking foam mats erase the metal edge and give some more comfort)
- left side has had an extension to contain other bits and pieces/stoves/bottles etc.
I made this DIY drawer system. It's mounted on the airline rails on the cargo floor. If I take the cargo wall out (4 screws) I can make it longer with that plate on top and create a flat surface to sleep. Need to shift the chairs in forward position. But you get a bed approximately from 1,9 meter x 1,2 meter + some extra space left and right. So enough for a short trip and not using the RTT, or ideal for stealth sleeping.
I can get a small fridge in it + food, kitchen and other stuff for a weekend away.
Still needs some painting to finalize.
I can also use it to store my Makita work-gear in during business days, to go to a site for depannage or montage.
Also received this week the Black Sheep Molle system for the interior panels left and right. Still need to mount this, probably a weekend job. I will post some photo's when done.
Did you remove the seats? or is your Grenadier the commercial 2 seat model?
Has anyone managed a drawer system of say 250-300mm height to get a length much more than 700mm? Anyone managed 900mm? I’m considering a cheap set of drawers initially but their 700mm set doesn’t come with a built in fridge slide, which for me is a mandatory requirement.
