This is a sample guest message. Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox! INEOS Agents, Dealers or Commercial vendors please contact admin@theineosforum.com for a commercial account.
Henry's Blog
You c
You can always fit a cheap BLE battery monitor to both batteries and take a closer look at what is going on. I have some screen captures from the BLE in my review of the rooftop solar panel here.
On my car, the BLE battery monitors and the Grenadiers SOC are broadly similar - both are estimating SOC anyway. I use the amps being charged to give me a good idea of where the SOC really is, 1 amp strongly suggests the batteries are close to 100% SOC (assuming the battery is working properly).
Thanks Michael
Yes getting some monitoring fitted is on my radar.... along with some sump guards, x-spec window mounts etc and getting my tax return in :) . I may go upmarket with Victron or Redarc shunts, only because I have their products and apps installed. Battery was tested as OK so my thinking is its either lazy alternator or more likely the BMW module has been programmed for city use.
My battery SOC generally hovers around the 80% mark. never above 82 unless I use an external charger and even then , only high 80s for a while.
I was reassured by this recent forum post:
"Maintaining the battery at approximately 80% SOC is by design. It's not a fault.
I discussed this with a senior BMW tech recently and he confirmed this is how BMW manage their batteries to reduce fuel consumption and extend battery life. In newer BMWs the target SOC is configurable to allow for the owner's usage pattern. For a city driver the alternator can be set to charge more aggressively during short trips and maintain the battery charge and ensure vehicle operation at the expense of higher fuel consumption.
This intelligent battery management is why we're seeing fluctuations in the charge rates during a drive cycle. Setting aside that there has been some reports of faulty batteries, my suggestion to the forum is to understand this is normal operation so stop fixating on less than 100% battery SOC."
Thanks Tazzieman
In my digging around the internet and forum that's my understanding as well, which is why I'm not too stressed and around 80% SOC may also extend battery life. But I would like to know why some cars like the loan vehicle I had, charge to 99% with higher amps coming from the alternator than a lot of our cars. Also it would be nice for the battery to fully charge so I have an extra 20-25 amp/hrs capacity when off grid. Still with a jump starter and a solar panel the worst that can happen is being parked up for an hour or so to recharge.
Finally talking with Paul Hennig last week he alluded to a forthcoming TSB that could also address this variability.
Steve
Roof Bars
For many years I’ve used Rhino HD square bars and as a result have a reasonable investment in fittings for them. While the INEOS Rhino roof bars are very well made and good value, the bar profile is different and they are only presently available in pairs.
Following on from the posts of @jb_hamon (eg https://www.theineosforum.com/threads/roof-racks-head-up-displays-and-dash-cams-etc-any-after-market-accessory.12410499/post-1333199557), I’ve fitted 3 1800mm HD Square Rhino bars. You could get away with 1650mm bars, but it would be tight. I already had 2 sets of RL210 legs fitted with S2 retaining straps (to suit a 70 series land cruiser) and purchased a third set of RL210DS8 legs (for a Landrover Defender) which had S8 retaining straps that are a slightly different profile and a couple of mm longer reach under the gutter. I couldn’t get the S8 straps as a spare part for my old feet, but the roof rack sales guy suggested buying a set of S5 straps used on a GU Patrol which have a significantly greater reach under the gutter. Unfortunately they only come in sets of 4 so had to buy 2 sets. Pic following illustrates the difference in reach.
S5 strap fitted
I’ve mounted the bars to the gutters, between and to the front and rear of the grab handles. I’m finding little or no gutter flex when I hang my 90kg off the bars in these positions. Since I’m not going to be carrying heavy loads on the roof, I’m not going to fit any further bracing or supports to the legs at this point in time.
View attachment 7843116View attachment 7843117
Steve
You do realise that gutters are the weakest mounting point of the entire roof being pressed metal. Therefore they do not provide the 150kg dynamic roof capacity, most assume.
Once again, the majority of most roof rack systems do not consider or cater for the Grenadiers 'flat roof' with 4x longitudinal rubber mounts and, more importantly, ignore the roof framing structure providing the load capacity.
Leitner Designs and Black Sheep have started to respond in their product line.
If the gutters are not strong enough as you say, why then do IA supply a rack to fit with a 5 year warranty?
I'm sure the engineers who designed it would differ.
The gutters are folded pressed and bonded. The roof may be rated but to load the roof strip's which aren't securely fixed to the roof is a weak point in both designs for Australian conditions
X2 @MrMike's comments.
As noted the last paragraph on my original post as I don't carry heavy loads, these bars and the mountings are fit for my purposes plus in over 40 years I have never had any issues with gutter mounted roof bars on other vehicles. If I was permanently mounting a roof top tent or carrying heavy loads though I would go for a different option.
Helena Aurora Ranges Take 2
After being washed out in April I finally made it back to the ranges the other week leading a group from the local Land Rover club. No rain at all this time!. We stayed at a very basic camp ground (really just a cleared area) at the base of the range and also did day trips from there visiting the Mt Manning BIF Ranges to the north west and old Mt Dimer gold workings to the east.
The ranges are folded banded iron formations (BIF) that have been turned on their side and stand around 200m above the surrounding land surface. Besides being geologically interesting they have unique flora and fauna and are of great cultural significance to the traditional owners of the area, the Kalamaia.
The weather was pleasant and there were still some spring wild flowers, especially in areas which had been recently burnt. Except for the main entry track from Koolyanobbing the going was slow and average speeds were 25-50kph. Tracks were not difficult but in places were variably rutted, twisty and tight/vegetated. One group member staked a tyre on the edge of the tread which needed 4 plugs to seal.
Henry handled the trip easily. Locked the centre diff and dropped the tyre pressures slightly on the gravel and in tight sections used off road mode, mainly to stop the parking sensors chirping from bushes brushing the car. I carried 2 jerry cans of diesel on the camper trailer, which gave me just on 1000km range before needing to refuel. This included 500km towing. Towing economy was in the mid 15l/100km area, with the display showing 11-12l/100km pottering slowly along the tracks.
Other statistical trivia. Including a short evening shower and washing up, I found my water usage about 25L/day. Using 1, 225w solar panel I was able to power the camper for 3 days before the batteries (200 amp Hr Lithium) dropped to 35%. Using 2 panels charged the batteries to 100% by lunch time. The 95l Dometic Fridge freezer in the camper trailer is the main energy consumer. It draws around 5 amps when running.
Steve
Camp area
View from the Helena Aurora Ranges
Tightly Folded BIF
Wild Flowers
Bungalbin is the aboriginal name for the Helena Aurora ranges
Mt Manning Range
Dimers Stone Hut
Steve
Camp area
Tightly Folded BIF
Wild Flowers
Mt Manning Range
Dimers Stone Hut
Great pics I would love to join in a future trip Don
Steve
Camp area
Tightly Folded BIF
Wild Flowers
Mt Manning Range
Dimers Stone Hut
How were the flies? Very friendly no doubt, great part of WA out there
A couple of other comments and observations from the recent trip.
Battery Charging.
I’ve always been a bit concerned that Henry never seems to get above 80% charged in normal day to day driving. At the start of the trip he was at 74% SOC but by the end it was at 96%. Monitoring the SOC during the trip showed most of the gain was made during the few days pottering around the ranges. I didn’t have any loads running beyond charging the camper trailer house batteries while driving to/from the ranges. As others have noted on the forum while initially disconcerting the low SOC percentages in around town driving are normal behaviour, so I’m I’ll stop worrying and make a note regarding this in the next edition of the manual.
Off-Road Navigation.
This was the first real test of running off-line imagery through OsmAnd Maps on the centre display, as except for the lookouts at the top of the range we had no mobile coverage. As I noted in another thread (https://www.theineosforum.com/threads/custom-maps-and-images-in-carplay.12416451/) it’s a clunky process to get Google or Bing satellite imagery into a format that OsmAnd Maps can read, but it's possible. However be aware file sizes will exponentially grow as you increase your resolution. For an area of 15,000 sqkm (150x100km) at 2 m resolution I ended up with a 10gb tile file, which took a while to transfer to my iPhone. It worked nicely. OsmAnd Maps did drop out a few times, probably due to tripping up on rotating the image but it restarted cleanly.
I used the satellite imagery for detail navigation and the published 250K GA mapping on the iPad for a more regional view. The detail was useful where tracks had changed from the historical mapping.
Another chap in the group also has success with using Google Maps and saving the area for offline usage. It appears that Google have captured a lot of the tracks from the 250K GA mapping and he was able to navigate using the way-points I had provided him.
Steve
Camp Light
An early Christmas present for Henry.
The small 7.8" Stedi LED light bars have been on my radar for a while and I rather liked @Shopkeep's installation on the roof rails. https://www.theineosforum.com/threads/work-light-on-roof-grab-bar.12415826/post-1333288456. However I wanted a light with an external switch, so I didn’t have to be reaching into the car all the time and also, an Amber light to mitigate the bugs. While I was working out how to rig up a weatherproof switch and also waiting for Stedi to get the Amber light back in stock, they released a dual colour amber/white light with touch sensitive dimable switches for each colour. All problems solved so I quickly bought one along with the small bull bar clamps.
The light came with a DT plug, bare end pigtail. I connected a DTP connector on the bare ends to plug the light into the roof outlets. I ended up soldering the connector pins as the pigtail wires too thin to properly crimp and in the future, I may solder another pigtail into the pins to make a splitter if/when I buy another light. As noted by @Shopkeep, the supplied 10mm bolts are too short and the cup heads, too wide for the bracket slot. I found some M6, 16mm, socket head, cap bolts that fitted the slot neatly from my local bolt specialist.
For the install I used the supplied 25mm plastic spacers. Getting the bracket bolted on the handrail was a bit fiddly, but I found screwing the bottom side up first and then rotating the bracket downwards into position to do the top side worked nicely. With a bit of fiddling, I was also able to get the wiring and pigtail adaptor neatly tucked inside the roof connector box.
I’ve no complaints with the performance of the lights with both the amber and white settings giving plenty of light. Press on the relevant side touch point to switch on and hold to slowly dim or brighten.
White Setting
Amber Setting
Finally, a couple of fine print details I initially missed on the Stedi web site which may be useful if you are considering mounting the lights on other bar work. The 22-30mm small pipe bracket has a 6.5mm slot, whereas the larger versions are 8.5mm. The larger versions also have grub screws and bolts which replace the short bolts.
Steve
Camp Light
White Setting
Amber Setting
Steve
I'd like the outputs wired to my aux battery, that way I can run those lights for some time and not worry about flattening the battery.
They don't draw much power, 1.1 amps, with both colors on maximum, so it would take a while to draw a battery down to 50%. I'd be more worried about the draw of a fridge and other 12v appliances.
Steve
6 Month Report​
It’s just over 6 months since Henry arrived so time for an update.
Since delivery we’ve covered just over 7000km which includes a reasonable proportion of off-roading and towing, so we have covered most of my use cases.
Aside of a few niggles I’m really happy with the Grenadier and have no regrets buying one instead of the opposition. The car meets my requirements for a modernised D2, i.e. live axles with a manually operated centre diff that can do low range unlocked, but with more power, a better auto and the modern conveniences like CarPlay etc and no driver assistance aids and electric park brake.
After a couple of visits to Magic the agent in Perth, most issues have been addressed or significantly mitigated.
  • Door seals have been replaced which has stopped the complimentary foot wash. Unfortunately, the small rear door was misaligned (incredibly hard to open) after the visit but I was able to adjust the latch plate on the big door to get it back into position.
  • PDC errors are much better, but I still see the occasional beep. Recently though they are becoming more prevalent with the recent wet weather and after I wash the car. I suspect the outer rear passenger side sensor will require replacement as it is a serial offender.
  • 1800rpm resonance/rattle has been mitigated to the point I rarely notice it. Magic apparently are still waiting for their replacement chassis vibration analysis tool. But I hope they will have it when next I visit.
  • I ended up getting a set of front checker plates fitted which broke up the paint shade mismatch. A good outcome as apparently no one in Perth at the time had been trained in the paint application process as its apparently a new technology.
  • Misaligned steering arms that were fouling have been adjusted and refinished.
  • Software updated including the major one and one for the passenger airbag warning. Henry hasn’t has the CarPlay update applied yet.
Fuel economy has improved and I’m seeing high 11’s/100km around town on the display. I’ve gotten used to the driving position and after a couple of long trips there are no aches and pains and the overall seating position is quite comfortable. That said I still occasionally find the left foot rest gets in the way. Mainly it’s when I try and stretch my left leg out plus having my left knee sitting higher than the right. Maybe one day there will be a solution that will get footrest and accelerator pedal better aligned.
Likes include:
  • Offroad gearing. Low range is lower geared than the D2 and with the increase in power and torque I can stay in high range longer. I still haven’t found the cars limits and am mildly ashamed to say that I have yet to use the front and rear diff locks.
  • The Aux power switches. I have the UHF wired to INT1 and can control my compressor through the NATO plug using the EXT5 switch while monitoring the tyre pressure on the central display in air conditioned comfort 😊
  • The L-tracks in the boot really improve the flexibility for tying down loads.
On the so so side:
  • I’m not a fan of the turning circle and most shopping car park bays need 2 bites to get into. It’s lot easier parking if the adjacent bay is unoccupied. Still, it’s better than a 70 series Troopy LOL
  • The B pillars are incredibly wide, so I have to make a conscious effort to move my head more when looking over my shoulder and when making turns.
I’m also finding getting timely support both from Ineos and Magic is still a work in progress. To be fair to Magic they have had a bit of staff turnover in the workshop recently so responses to emails takes time. With Ineos support most of my queries have had to be referred up the line and sometimes replies are slow.
Steve
Hi there. You say your dealer managed to mitigate the 1800-2000rpm resonance. Do you know what they did? Like many others, my diesel trial aster suffers the same problem and desperate to get it sorted. Thanks.
Hi @Hill Billy
As it was a while ago my memory is a bit vague, but i recall it was adjusting/ bending some heat shields around engine and exhaust on various places.
Steve
First Year Report
Well, my first year of grenadier ownership is over and time to jot a few thoughts down.
It’s been a bit of a journey, but Henry has settled into the motley collection of not so classic cars and more importantly I have grown used to his idiosyncrasies and he and the Grenadier species have few! It helps that I’m well used to idiosyncratic automotive brands, so I can easily forgive their foibles.
So no regrets buying a grenadier. There is nothing else out there that comes close to my old Discovery 2a.
As to be expected for a new manufacturer, dealer and business model, he’s had a few teething issues, but all bar one have been resolved and none have been major. Most have been noted in previous posts and are well known to the community here, so I won’t repeat them. The only outstanding issue, which recently appeared, is the driver’s seat not staying up and slowly subsiding to the floor over 2-300km of driving. The seat was tightened at the first service in late November but still is dropping, so needs another visit to rectify.
We’ve travelled just over 11,000 kilometres during the year. It would have been higher, except he was off the road at Magics for a few weeks back in February and I have had several trips away, where he was parked up.
Average fuel economy has been 13l/100km. This is based on actual litres used and km driven at each fill-up and are slightly higher than what the centre display reports. It includes approximately 1/3 towing. Worst was 17l/100km, towing the fully loaded camper trailer into a headwind and best 11.5l/100km around town.
Unlike others I’ve been restrained with fitting accessories. Major $ items fitted post-delivery included:
  • Trailer brakes, Anderson trailer power, 13pin connector adaptors and shallow drop hitch tongue.
  • Roof bars.
  • UHF radio install.
  • Roof outlet and Nato plug wiring adaptors.
  • A new set of field spares, e.g. fuses, fluids, filters etc.
Looking forward I have an itch to get some under body bash plates and a shunt for the Aux battery, along with a LeTech rear jerry can ladder and some side window mounts to carry extra fuel. Currently I carry, 2 jerry cans which gives me almost 1000km with 50% towing and have space for a third, so ladder and side mounts are not critical until I do something like the Canning stock route.
Maybe this year we’ll see some sort of maintenance manual………………
Steve
First Year Report
  • Roof bars.
Steve
No you mentioned it, I too have the seat that keeps lowering itself.
Also like you I have no ongoing issues,.its a wonderful vehicle
Internal Anderson Charger Connector
I finally got around to making and installing an under-seat Anderson plug harness for my Victron solar regulator to charge the vehicle batteries. Now I don’t have to use the engine bay jump posts and can keep the regulator out of the weather. Using a bit of Velcro the Anderson plug can be secured out of the way under the seat when not in use.
As it was a warm 39deg day I didn’t take as many photos as I normally would have, but the following provide some illustration. All worked perfectly with a brief test run using my solar panels and Victron regulator. Interestingly the Victron regulator puts out enough volts to wake up the smartpass to start charging the Aux battery as well.
Stored on Velcro patch.
Shopping list for the harness comprised, a length of 8awg dual core cable, Anderson plug and 10mm pins, 2, 10x8mm battery lugs, 2, 10x5mm battery lugs, some adhesive heat shrink and protective split conduit. I also added an inline 50amp midi fuse so it can be used in future as a power outlet to charge a third battery through a DC-DC charger.
Completed Harness
Installation was reasonably simple. Removing the rear plastic cover on the starter battery side needed a bit of fiddling, but I got it out eventually. I had to admit defeat for the same cover on the auxiliary battery side, but it still needed to be unbolted so I could remove the starter battery rear cover.
The harness is connected to the starter battery positive terminal and the negative earth bolt on the floor between the interior fuse box and seat support. Using the floor negative earth keeps the IBS/BMS sensor in circuit to register SOC etc. To get to the bolt, I needed a long extension on my ratchet and also remove the rear battery cover.
Negative earth bolt with negative harness wire attached. cable above my finger goes to the starter battery.
Positive wiring, Midi fuse holder to left of Auxiliary high load fuse box, cable tied to the battery handle.
I learnt a couple of things from doing the install.
  • I made sure to leave plenty of time for the electrical systems to go to sleep, including leaving a door open, turning off the interior lights and leaving the key in the house. But opening another door seemed to wake the car up, as I got the brief whirring sound, even though the centre display didn’t turn on. I’ll make a couple of extra notes on this in the next manual update.
  • I got a temporary error light on the Smartpass when it was reconnected, indicating start assistance had been triggered. It went away after I started the car and it connected the Auxiliary battery to start charging. I had to find the Smartpass manual to work out what the error light meant so I will put a table in the next manual release with explanations. Thankfully no other error lights or airbag warnings.
Steve
Completed Harness
Steve
Nicely done @Rok_Dr
Your left index looks like roadkill. What have you done to it? :oops:
Your first blog post was 2nd Feb so you have an anniversary coming up 🥂
Blame the colour balance on the phone getting out of sync and a few scratches from tree pruning without gloves the day before.
Time flies!
Steve
