That's smart - does anyone know if there is a US distributor?
Probably best contact the manufacturer and see what they say.That's smart - does anyone know if there is a US distributor?
Hi @Rok_Dr , I took delivery of my Grenadier on Friday, it has the PDC malfunction (just doesn't work). Do you know what the dealer did to fix yours please?I currently driving a loan Grenadier while Henry is at the dealers getting a few issues attended to. Its interesting comparing the 2 cars. The loaner is a very low VIN number trialmaster diesel without a bullbar or winch. Not a peep from the front parking sensors and it is perceptibly less Gruff accelerating through the 1800-2000rpm resonance rattle zone. Steering doesn't pulse during low speed manoeuvring at the shopping centre.
Update from the dealer today is that they think they have solved the front PDC errors, have made progress with the 1800-2200rpm resonance rattles, but have a couple of more things to try, fitted the new door seals and applied yet another software update. Parts have been ordered for the rubbing steering arms and they will also look at the steering pulsing.
Steve
Hi @SteveoHi @Rok_Dr , I took delivery of my Grenadier on Friday, it has the PDC malfunction (just doesn't work). Do you know what the dealer did to fix yours please?
Cheers,
Steve
Thanks for sharing the info. Dumb question, but is it the standard Redraw tow pro, or something specific from Ineos?Towing Preparation
First up the electric brake controller. I decided to go as standard as possible retaining the 13 pin EU trailer plug and getting the Ineos Redarc brake controller kit fitted.
The kit was installed by my trusted auto sparky (Schultz Automotive in Willetton for those SOR in Perth). It was not cheap as this was the first Grenadier they had seen, but they did a very neat job. I also got them to run an Anderson plug to power the trailer off the main battery, to avoid the hassles of using the NATO plug and an adaptor. They fitted it neatly in a weatherproof enclosure next to the trailer plug, wired off the main battery.
Anderson Plug location
I bought a Narva 13pin EU to 7 pin flat wiring adaptor and rewired it so the power from EU plug pin 9 goes to pin 2 on the flat plug, The camper needs a hot wire to pin 2 to trigger the Redarc BMS to charge the house batteries from the Anderson plug when the vehicle is running. Modified schematic pic below.The trailer doesn’t have reversing lights. As an aside the Narva adaptor is wired up as standard to match the Grenadier Redarc electric brake install with the brakes on pin 12 of the EU plug and going to pin 5 on the flat plug.
Modified adaptor wiring schematic.
Moving on to tow hitches. Firstly the standard rear INEOS hitch receiver has an opening approximately 1mm smaller than most other hitch receivers in Australia. As a result not all 50mm tongues fit, so if you are buying another tongue test it before you buy. The camper trailer had a slight nose down attitude using the standard INEOS hitch, which has a 2.5" drop. I bought a Hayman Reece tongue which has a 1” drop. All sits pretty flat now (see pic in post #1)and the number plate is still visible.
I optioned Henry with a front tow hitch receiver as it seemed like a good idea at the time. I’m glad I did as it makes moving the camper trailer up my tight angled driveway so damm easy. Plus I can just idle it up the drive using low range unlocked.
Steve
*RedarcThanks for sharing the info. Dumb question, but is it the standard Redraw tow pro, or something specific from Ineos?
There's this alternative tooRefuelling Adaptor Nozzle
An essential accessory!!
The Grenadier fuel filler will only allow a small diesel nozzle to be inserted to fill the car. This is due to the misfuelling flap fitted in the inlet. While I can understand the need to stop misfuelling mistakes, this means you can’t easily fill up using a jerry can or at truck bowsers. A fundamental limitation for remote Australia.
I purchased the following adaptor from a local Auto One parts store. Similar adaptors can be found on E bay and apparently VW/Audi also make one as a spare part. Pro-Quip also make a jerry can spout with the right sized end. The equivalent petrol adapter has a smaller diameter.View attachment 7842441
Works nicely with my standard Jerry can nozzle, but I’ve yet to see if it will allow me to refuel using a large truck bowser nozzle.
Steve
Nice bit of lateral thinking there DaveB and if the outlet is 25mm you're onto a winner................ but if you borrowed it from a friend then I'm not sure they would want it back after a jerry can of diesel had passed through it.There's this alternative too
She'd be a pretty robust friend if she passed a jerry can of dieselNice bit of lateral thinking there DaveB and if the outlet is 25mm you're onto a winner................ but if you borrowed it from a friend then I'm not sure they would want it back after a jerry can of diesel had passed through it.
Steve
Clever idea with loops under seatsCargo Tie Downs and Restraint
While I’m patiently awaiting Henry’s return , I've put a bit of thought into securing gear inside the car. Overall I’m pretty impressed with the Grenadier’s tie down point locations and the floor L Tracks on the Trialmaster, but forward of the D loop at the rear bottom base of the rear passenger door apertures there isn’t anything to restrain gear on the rear seat when it’s folded. In keeping with most of my mods it involves no cutting or drilling to the vehicle.
The rear seat has a pretty substantial base frame so my solution was to secure a number of tie down loops to the frame and feed them through the folded cushions to provide accessible lashing points to the front and sides of the folded seat. The tie down loops can be found at most auto accessory and camping stores. The following pics tell the story, with my ancient Waco 40l fridge secured as an example.
For larger loads I’ll use a rated cargo net (https://www.safeguardnet.com.au/) to secure the load. Thankfully the small net I had for the Disco 2 fitted the Grenadier nicely. Again, pics Illustrate the concept. Though not seen in the pics there are also tie down straps secured to L track fittings towards the folded seat. I still need to do a bit more fiddling when Henry returns to refine the net fitting when the Cargo barrier is fitted.
Steve
Tie down loops. Lashing capacities are typically 350-450kg depending on brand.
View attachment 7847799View attachment 7847801
Loops attached to seat frame.
Lashing attachment detail
View attachment 7847802View attachment 7847803
View attachment 7847804View attachment 7847805
Cargo Net
Great workCargo Tie Downs and Restraint
For larger loads I’ll use a rated cargo net (https://www.safeguardnet.com.au/) to secure the load. Thankfully the small net I had for the Disco 2 fitted the Grenadier nicely. Again, pics Illustrate the concept. Though not seen in the pics there are also tie down straps either side, secured to L track fittings towards the folded seat. I still need to do a bit more fiddling when Henry returns to refine the net fitting when the Cargo barrier is fitted.
Steve
Cargo Net
question: does the "1537" on the label represent a size... was thinking about the 2.2m x 1.6m version for my Grenadier...Cargo Tie Downs and Restraint
Steve
Cargo Net
