Heated Seats Not Working
G-Man
8:19 PM
Aberdeen, Scotland
I went to use the heated seat for the first time on my way into work this morning (Autumn is calling) and nothing happened.
Anyone else had this issue? When I get time my first port of call will be the fuses but any advice welcomed thanks
Hi Man,
You can see if this actions could help:
You-Check the fuse for the heated seats.
Inspect the electrical plug underneath the heated seat where it connects to the main wiring harness.
Reset the heated seats by disconnecting and reconnecting the battery.
Well it's working today. Made sure the plug under the seat was well seated but didn't swap out any fuses.
Its comfortable on 1/3 setting but butt-searingly hot on 3/3 setting so will hold off using that level unless I'm hypothermic. 😆
It won’t work in wading mode. But I presume that was not your use case as you wondered why it wasn’t working 😀
I’ve encountered the same issue. Seats do not heat although buttons are illuminated. Checked the fuses and they were fine. Connectors under each seat appear to be intact and seated properly. Could try disconnecting the battery this evening…any other suggestions?
