Headlight High Beam Not High Enough
G-Man
8:36 PM
Aberdeen, Scotland
Hi Folks,
At maximum adjustment (using the levelling wheel in the cab) my headlight high beams still don't seem to cast the light far enough compared to previously owned vehicles. I have the tow pack which I believe also gives you stronger springs at the rear axle and there's a very pronounced 'downward dog' stance to the vehicle when running empty. I know others have fitted front axle spring spacer kits to balance the front to back ride height, but this is a pricey option just to level the headlights.
Has anyone on the forum looked at manually adjusting their headlights yet?
I did ask for an adjustment because my driver side (left hand NAS) is visibly lower than the passenger side. I was told this is normal for the benefit of oncoming traffic. Not sure if that's BS but it did make sense.
