I'm not sure that's how I understood the issue.I was on Facebook and someone mentioned the underbody grommets are put in incorrectly. They have a tendency with little pressure to fall out. When wading water egress is possible. Worth checking and correcting if need be.
Interesting... just 'lost' the exact grommet whilst fitting a busbar over it (busbar to service the ctek smartpass consumable out). Hardly touched it and now somewhere in a subframe I can't get to. The hole is 25 x35mm and seems it's the only grommet of that size that I can find in the vehicle. Wonder if the dealer has one...I was on Facebook and someone mentioned the underbody grommets are put in incorrectly. They have a tendency with little pressure to fall out. When wading water egress is possible. Worth checking and correcting if need be.
Just checked under the seat and yep, missing the same grommet as well. Can see the pavement under the vehicleI was on Facebook and someone mentioned the underbody grommets are put in incorrectly. They have a tendency with little pressure to fall out. When wading water egress is possible. Worth checking and correcting if need be.
Just checked mine - build Jan 23 - looks like someone has checked it as it has been marked - it’s as solid as - just felt it, (gingerly at first) with my fingers - it feels like you’d need a screwdriver to dislodge it.Just checked under the seat and yep, missing the same grommet as well. Can see the pavement under the vehicle![]()
Very well seen, I didn't notice, but indeed:It seems to be a Mercedes part
We have a smart car too JeanVery well seen, I didn't notice, but indeed:
https://partsouq.com/en/catalog/genuine/diagram?c=MB201810&ssd=$*KwGHs6KyzNrf2uH39uulkd_L6-zyg4yBgJKUm930yJDDlonfmY6SmZbe0ZeOkYPZ08-AgJGel8fQk9bA3JmW3tmXjpGAqrHcmZbQ3JeOkYfft9yZlsXRl46RgM6fAAAAAD-dZ8s=$&number=A0069893085
[EDITED] Google this "A 000 998 07 90"
You're going to post some photos of this, aren't you?Interesting... just 'lost' the exact grommet whilst fitting a busbar over it (busbar to service the ctek smartpass consumable out).
Exact same as Jean's.. thanks for the image JeanYou're going to post some photos of this, aren't you?![]()
Jean, I’ve just been out and done exactly the same and managed to fish it out with a pair of snipe nosed pliers. It was easy to remount and I’m considering gaffering it down. This will stop it being pushed up, or down and be semi permanent. Unless I’m missing something, do you think this is an effective work around?As I am a stupid guy who wants to know if wat people say is true, I pushed gently on the grommet, really gently, and oops...gone.
But I am also very patient, and found it back: I have quite long and small fingers, therefore putting my little finger in the middle hole of the lower part of the tank protection, I was lucky to feel the grommet! And with the help of an iron wire I pushed the grommet to one side (side of my thumb on the picture below, and again with my little finger I could get it out!
@DCPU is right: the grommets are placed in the right way as to resist water pressure, but to be honest this is quite poor design, not fool proof (the fool being me) !
After looking at the protection plate of the petrol tank, I am even not sure that I would be able to place the grommet back if I dismount it. I think (but am not sure) that I should have to dismount the tank too.
I placed it back the wrong way.
What one could do (even those who lost the grommet) is putting some metal plate that holds down the grommet or holds down some other piece of rubber as a replacement.
I repeat: poor design, I am not the only fool on the world!
Man, don't forget English isn't my mother tongue, what does "gaffering" mean?Jean, I’ve just been out and done exactly the same and managed to fish it out with a pair of snipe nosed pliers. It was easy to remount and I’m considering gaffering it down. This will stop it being pushed up, or down and be semi permanent. Unless I’m missing something, do you think this is an effective work around?
Recovered mine relatively easy with 'gaffer'/'duct' tape and I'll use same to secure it in place. Thanks again Jean for 'taking one for the team' as they say.. you're a champion!!Man, don't forget English isn't my mother tongue, what does "gaffering" mean?![]()
I am NOT an expert, I am like most of us playing, experimenting, trying, ... therefore not an expert![]()
Exact same as Jean's.. thanks for the image Jean.
