Grenadier.Parts - Rails, Bags, Glare shields.
Grenadier.Parts
Supporting Vendor
5:04 AM
Germany - Hessen
The Grenadier is our passion.
We offer selected, high-quality and useful accessories for the Ineos Grenadier.
Inexpensive problem solvers and also extensive extensions for individualisation are in the range, which is constantly being expanded...
https://grenadier.parts/en
Grenadier underseat storage bag (99,- €)
Under seat bag for the Grenadier,
high-quality, hard-wearing foamed Cordura, water-repellent and non-stick coated, with leather handle to match the interior.
Handmade in Germany to a high standard of quality, custom-fit for the Grenadier. (fits driver and passenger side)
This practical accessory offers you an additional, discreet storage option that is ideal for all the important little things you always want to have to hand.
https://grenadier.parts/en/products/untersitz-aufbewahrungstasche
Grenadier Untersitz Aufbewahrungstasche
Untersitztasche für den Grenadier,
hochwertiges, widerstandsfähiges geschäumtes Cordura, wasserabweisend und Anti-Haft beschichtet, mit zum Interior passendem Ledergriff.
In Deutschland mit hoher Qualität handgefertigt, passgenau für den Grenadier. (passt für Fahrer- und Beifahrerseite)
Dieses praktische Zubehör bietet Ihnen eine zusätzliche, diskrete Aufbewahrungsmöglichkeit, die ideal für alle wichtigen Kleinigkeiten ist, die Sie stets griffbereit haben möchten.
https://grenadier.parts/products/untersitz-aufbewahrungstasche
Alternative grenadier railing tube (set of 4) in red / in black or polished stainless steel
Discover our alternative railing tube, which combines design, functionality and durability in one product. This railing tube is available in high-strength aluminium, both in black (RAL 9005) and powder-coated red (RAL 3020). Alternatively, it is also available in robust stainless steel (+ approx. 1.5 kg) to meet different requirements and preferences.
Length: approx. 60cm
A set of 4 tubes is always sold.
https://grenadier.parts/en/products/relingrohr
alternatives Grenadier Relingrohr (4er Set) in rot / in schwarz oder Edelstahl geschliffen
Entdecken Sie unser alternatives Relingrohr, das Design, Funktionalität und Langlebigkeit in einem Produkt vereint. Dieses Relingrohr gibt es aus hochfestem Aluminium, sowohl in schwarz (RAL 9005) und rot gepulvert (RAL 3020). Alternativ auch in robustem Edelstahl (+ ca. 1,5 Kg) erhältlich, um unterschiedlichen Anforderungen und Vorlieben gerecht zu werden.
Länge: ca. 60cm
Verkauft wird immer ein Set, bestehend 4 Rohren.
https://grenadier.parts/products/relingrohr
Grenadier glare shield for the reversing camera
The covers made of aluminium with a plastic surface are simply mounted on the upper screw of the number plate illumination, fixed with the pre-mounted adhesive tape and screwed tight by replacing the screw with the enclosed, longer screw (Torx20).
The licence plate remains sufficiently illuminated, glare from the reversing camera is prevented and the camera image is much easier to see.
https://grenadier.parts/en/products/blendschutz-fuer-die-rueckfahrkamera
Grenadier Blendschutz für die Rückfahrkamera
Die Verblendungen aus Aluminium mit Kunststoffoberfläche wird einfach an der oberen Schraube der Kennzeichenbeleuchtung montiert, mit dem vormontieren Klebeband fixiert und durch Austauch der Schraube mit der beiliegenden, längeren Schraube (Torx20) festgeschraubt.
Das Kennzecihen bleibt weiterhin ausreichend beleuchtet, eine Blendung der Rückfahrkamera wird so entsprechend unterbunden und das Kamerabild ist wesentlich besser zu sehen..
https://grenadier.parts/products/blendschutz-fuer-die-rueckfahrkamera
Hi AlexandruAst
Thank you for your feedback,
We regret that you are not satisfied with our products.
Your complaint could have been sent to us directly.
I have no idea what your background and intention is in writing this.
We take justified criticism seriously, but we don't want to just leave it here.
The tubes are made of the same material and the same material thickness as the originals, are powder-coated and degraded at the ends. The plastic caps are even higher quality than the originals, they are slightly shorter, but hold a little better as the lamellae do not break so quickly and are slightly more flexible than the originals.
Personally, I don't think the silver powder coating on the original pipes is particularly good, as they started to stain after a short time on our car.
If you want heavier bars, you are welcome to purchase the stainless steel ones, which can also withstand higher lashing forces.
The bags fit right up to the stop on both sides; you may still have something under the seat that you can't push in all the way. The bottom of the bag is specially shaped so that the bag lifts slightly at the end and can therefore be pushed in completely on both sides. It then holds on to the front edge of the Ineos entry cover strip. They may simply not have been inserted all the way over the edge of the insertion strip.
You are welcome to contact us directly.
Grenadier.parts
Alexandruast
If you can take the time to write a negative report here, surely the supplier deserves the chance to redress the problem first hand. It seems a bit unfair to put people off their products without some form of communication first.
Alexandruast
I deleted my messages so they can investigate and sort the things out
Yes, very clear pictures, unfortunately they are not correct, they are probably supposed to show that the left pocket does not fit...
Of course we know about the bumper on the left-hand side, the bag was specially developed with the base so that it slides over the raised section on the left-hand side and therefore fits on both sides.
In the picture where the bag is sticking out, it is not fully inserted, as in the picture which shows the bag under the seat.
When the bag is fully pushed in, it does not stick out at the front.... but closes flush on the outside...see our photo below...
Unfortunately I have to question again what this customer is trying to achieve with his (even wrongly illustrated) accusations,
we have already supplied the bags to several hundred customers, strangely enough they fit all these customers on the left side without any problems.
Many customers first buy just one bag to try it out, most of them then buy the second bag because they have tried it out and found that it also fits on the left side.
He had also stated in the past that our tubes are much lighter than the originals (which I was able to disprove above with a scale..., they are even slightly heavier...).
So what is this user's intention !
We are users of Grenadier ourselves and try to find solutions to existing problems or small improvements, create them and offer them to other users.
We are always open to constructive suggestions.
I don´t like such only bashing people and offer him to return our goods, he gets his money back...
I still plan to purchase a pair from you and hopefully have the success that most of your customers have. Could it be that Alexandruast was supplied with the wrong size? Either way, if he can have his money back. Nothing is lost.
We only make the bags in one size so that they fit on both sides. This gives the user much more flexibility.
I will be happy to await your order and send you the bags so you can try them out for yourself...we have them directly in stock...
I have the Black finished bars on my Trialmaster and think they are well made and a good finish.
Do you have any photos PBD of the black bars, thinking of purchasing.
Tks
Grenadier Parts
If Alexandruast returns them, can I buy them at a discount? I want a pair with the brown handles. 😊
I cannot return them, they ended up in the trash 😅
It's very weird how some people think that others have hidden intentions simple from being disappointed by their products.
Maybe I have some impossible expectations for the products I put my money on to actually fit. My logic is the following: if I am going to compromise, I am going to compromise cheap. If I pay, I expect quality and perfect fit. But that's just me, that's why I deleted my initial harsh comment.
BTW, this is how the LHS bag looks after a day offroading, Grenadier.parts can clearly see it does not stay properly and it can be seen from their pictures where they claim it's normal for the raised (not fitting) LHS bag, which I personally find unacceptable.
Regarding the bars, it's a personal opinion and anyone should take it as so. I didn't put them on a scale. They felt lighter, cheaper, and with lower quality finish than the OE bars. Maybe they are heavier, maybe I received a bad batch, a lot of maybes. I don't have time and energy to exchange, argue and explain myself to vendors. I just choose to not buy from them. My choice.
When the bag is inserted correctly, it closes flush at the front and hangs a little behind the bump of the plastic moulding.
Of course, the loaded bag can slip out a little when riding off-road, when it gets bumpy, it has no locking hook, you push it back, it stops behind the plastic moulding and that's it...
As I've already written, I'm happy to accept constructive suggestions, but that's different from bashing it doesn't fit...
