Grenadier.Parts - Rails, Bags, Glare shields.
The Grenadier is our passion.
We offer selected, high-quality and useful accessories for the Ineos Grenadier.
Inexpensive problem solvers and also extensive extensions for individualisation are in the range, which is constantly being expanded...
https://grenadier.parts/en
Grenadier underseat storage bag (99,- €)
Under seat bag for the Grenadier,
high-quality, hard-wearing foamed Cordura, water-repellent and non-stick coated, with leather handle to match the interior.
Handmade in Germany to a high standard of quality, custom-fit for the Grenadier. (fits driver and passenger side)
This practical accessory offers you an additional, discreet storage option that is ideal for all the important little things you always want to have to hand.
https://grenadier.parts/en/products/untersitz-aufbewahrungstasche
Grenadier Untersitz Aufbewahrungstasche
Untersitztasche für den Grenadier,
hochwertiges, widerstandsfähiges geschäumtes Cordura, wasserabweisend und Anti-Haft beschichtet, mit zum Interior passendem Ledergriff.
In Deutschland mit hoher Qualität handgefertigt, passgenau für den Grenadier. (passt für Fahrer- und Beifahrerseite)
Dieses praktische Zubehör bietet Ihnen eine zusätzliche, diskrete Aufbewahrungsmöglichkeit, die ideal für alle wichtigen Kleinigkeiten ist, die Sie stets griffbereit haben möchten.
https://grenadier.parts/products/untersitz-aufbewahrungstasche
Alternative grenadier railing tube (set of 4) in red / in black or polished stainless steel
Discover our alternative railing tube, which combines design, functionality and durability in one product. This railing tube is available in high-strength aluminium, both in black (RAL 9005) and powder-coated red (RAL 3020). Alternatively, it is also available in robust stainless steel (+ approx. 1.5 kg) to meet different requirements and preferences.
Length: approx. 60cm
A set of 4 tubes is always sold.
https://grenadier.parts/en/products/relingrohr
alternatives Grenadier Relingrohr (4er Set) in rot / in schwarz oder Edelstahl geschliffen
Entdecken Sie unser alternatives Relingrohr, das Design, Funktionalität und Langlebigkeit in einem Produkt vereint. Dieses Relingrohr gibt es aus hochfestem Aluminium, sowohl in schwarz (RAL 9005) und rot gepulvert (RAL 3020). Alternativ auch in robustem Edelstahl (+ ca. 1,5 Kg) erhältlich, um unterschiedlichen Anforderungen und Vorlieben gerecht zu werden.
Länge: ca. 60cm
Verkauft wird immer ein Set, bestehend 4 Rohren.
https://grenadier.parts/products/relingrohr
Grenadier glare shield for the reversing camera
The covers made of aluminium with a plastic surface are simply mounted on the upper screw of the number plate illumination, fixed with the pre-mounted adhesive tape and screwed tight by replacing the screw with the enclosed, longer screw (Torx20).
The licence plate remains sufficiently illuminated, glare from the reversing camera is prevented and the camera image is much easier to see.
https://grenadier.parts/en/products/blendschutz-fuer-die-rueckfahrkamera
Grenadier Blendschutz für die Rückfahrkamera
Die Verblendungen aus Aluminium mit Kunststoffoberfläche wird einfach an der oberen Schraube der Kennzeichenbeleuchtung montiert, mit dem vormontieren Klebeband fixiert und durch Austauch der Schraube mit der beiliegenden, längeren Schraube (Torx20) festgeschraubt.
Das Kennzecihen bleibt weiterhin ausreichend beleuchtet, eine Blendung der Rückfahrkamera wird so entsprechend unterbunden und das Kamerabild ist wesentlich besser zu sehen..
https://grenadier.parts/products/blendschutz-fuer-die-rueckfahrkamera
I bought the bag for under the seat. Fits like a glove. Perfect. Well made. My tire repair kit is under the passenger seat (Velcro’d in) and wouldn’t fit in this bag or I would have purchased two. Put the one I received under my drivers seat. Love it. Perfect for stuff I don’t need to get at right away but need a place to stow it.
I've had one of these since before I bought my Grenadier - and it was packed to the gills. Fit perfectly fine under my driver's or passenger seat. Not sure why there's any debate as anyone who has them knows they just fit.
I like the look of these bags. The red/brown handles appear to go nicely with the saddle leather. So, once mine is delivered in August (I will probably delay it to 1 September because of the registration change date), I will look to order them.
In my Defender 90, I have all sorts of stuff in my cubby, but I am hoping that much of it will go into the bags, leaving the Grenadier cubby less cluttered.
Thank you very much,
the order will be dispatched to you tomorrow...
They arrived very quickly. Was away travelling so only fitted today. They are very nice indeed. Thank you.
