Goodwood Revival 16th - 18th September
Look at the picture. Red: rope roller (I guess), Green: number plate hinge (I'm sure).
Thanks a lot. (y)
The front winch doesn't actually seem to be mounted, the slot looks empty.
sorrey emax, I did not get it. Why do you know, that the silver one has the winch?
As you said the bumper looks shorter (and better)
The silver one clearly has the hinged front number plate. That could just be there for the sake of it, but would be needed for either the winch or the front hitch receiver.
Perspective distortion is of course an issue. But the green line has clear references at the screws. This at least shows, that there is a difference.
Judge for yourself:
You're a star ~thank you very much. 👍
@bemax
Different B : C relations are unmissable.
Green line distance to bumper edge as well.
Depending on whether you are wearing your best clothes or have a selfie stick... a photo or two of the back/bottom of the transfer case showing the oil cooler piping arrangements would be nice.
Also, is this plug connected, or just resting in the cutout?
Those bumpers... one steel, one plastic?
@bemax
DIfferent B : C relations are unmissable.
Yes that’s right. But from nearly the same angle it looks not that bad at the dark one. Don’t you think so?
