I am looking at installing Dometic 140 Litre upright fridge in the back but make it relatively easy to remove
It weighs 30kg
My thoughts are to put a flat panel across the floor mounted using the utility rail
Then mount a timber cage to that panel.
Slide the fridge in and fasten it off.
Plug the power into the 12vDC socket in the back
It shouldn't take more than 30 minutes to install or remove
Instead of pulling into a service centre and buying expensive junk food I can just walk around the back and get something much cheaper and healthier.
Also good when bringing groceries home on the 30-40 minute drive on 35 degree days
It weighs 30kg
