Build Thread FL450's Build
11:04 AM
Napa Valley, CA, USA
Selling my 1993 NAS Land Rover Defender #99 has got to be one of the greatest regrets I may have ever had. What an icon that car was.
As fantastic as that truck was to build, it seemed no level of meticulous restoration could achieve the reliability, safety, and comfort we come to expect in a modern vehicle. On one of the many days the Defender looked at me the wrong way, a customer of mine made me an insane offer and I let it go.
So off I went to replace it with something more modern. Surely something out there exists that could be better right?
They were all great...but let's be honest...they will never have the heritage or nostalgia of the 110. Will the Grenadier be just another one like the rest?
Something tells me this one is different.
I ordered my Grenadier almost 14 months ago. After almost giving up hope I finally got a call that it was ready for delivery. A new dealership in the Bay Area had formed and I guess my car was part of the original seed stock. At around $93,000 sticker price, the Trialmaster was fully loaded but still missing many of its apparently dealer installed options. It took about 3-4 days to get the rest of the gear in stock but the dealer did a great job installing the factory options and my truck was finally ready for delivery.
Finally it came home.
Now for the build stuff. Normally I'm usually inclined to a modest 30mm lift but the Grenadier didn't seem to need it. I changed the rubber for 285/70 R17s in the Toyo R/Ts. I actually really like the stance as it is and there is plenty of clearance. Even loaded down it has a logical stance.
My plan is the following:
  • 285/70 R17 Toyo R/Ts
  • OWL Outdoor Rosen Sun Shades
  • OWL Outdoor ARB Twin Compressor
  • GP Factors Rear Cubby Table System
  • Diabolical Rear Drawer System
  • S2 Baja Lights on Rack
  • Grenadier Stock Light Bar on stock Rhino Rack
  • OWL Outdoor LP4 Baja Design Aux Light Replacements
  • 67Designs Gear Accessory Rail
  • ICOM 5100 HAM Radio
  • Compactenna 2m x 70cm HAM Radio Antenna and front bumper mag mount
  • Dometic Fridge and Slide to mount on top of Diabolical Drawer System
I started with the 67Designs 20 mm ball mount system. The little trim piece around the screen easily pops off so I modified the mount with counter sunk hardware and drilled into the trim piece for a more solid hold. I'm disappointed 67D didn't plan this like this originally. Either way with a little modification it works and you end up only having the drill the top trim piece which can be replaced easily if needed.
img_0056-jpeg.7872196
At the same time, I installed the ICOM 5100. It's my favorite HAM radio for remote applications. I installed the antenna on the front bumper via a very strong magnet with gasket. The ground plane isn't too bad actually...and supports my needs well.
img_1938-jpeg.7872198
Next came the drawers...an easy evening install and very well built. I like that it's one large drawer with dividers. It also levels out with the seats folded forward which makes for a nice flat platform.
img_1910-jpeg.7872199
Also the GPFactors rear drawer is fortunately compatible. This is a very nice piece of kit.
img_0057-jpeg.7872200
Installed the OWL Outdoor Sun Shades and the ARB Twin Compressor. Again super well made. Rosen makes very high quality sun shades that are optically tested. I'm a corporate jet pilot and have similar style shades in the PC24. Really nice equipment for a vehicle and nice to look through.
img_0055-jpeg
img_1977-jpeg.7872205
img_1974-jpeg.7872204
img_0055-jpeg.7872202
Now the lights... The dealer installed the factory light bar which took one of the 4 awesome roof accessory plugs. I was able to only use 2 more for the side and rear lights. Leaving one more for possibly a StarLink in the future.
The Rhino Rack offers lots of great locations to mount lights. There is even a cool rail on the bottom of the rack at the rear which made mounting below the roof line easy.
As for the LP4s I mounted them using OWLs really cool AUX light replacement kit. I used the factory wiring to trigger a relay since they draw a lot more amps. I did use EXT1 to run the day time running lights which are just cool.
img_0051-jpeg.7872206
img_0052-jpeg.7872207
img_0054-jpeg.7872208
I am looking to install a GMRS radio and was wondering how and where you ran the antenna wire?
I am also looking to install a GMRS radio but would like to mount the antenna on the rear ladder or rear side near roof.
Anyone know of any rear entry points they have used to run antennas wires . Any pictures would be great.
Not sure if any one has a diagram or list of all exterior entry points that are easily accessible from outside and or inside the Grenadier
Thanks.
FL450, great job. I suggest moving the lead weights placed on the outside of your wheels and attach them on the inside of the wheel. Hides them.
