I saw that too and got nervous for two reasons.An interesting note from the NA configurer - the checker plates are listed as a dealer install. I assumed they were a factory fit.
- They could charge us a lot for install.
- They could mess it up.
Couldn't agree more - especially point 2!!!I saw that too and got nervous for two reasons.
Pros are we could purchase and install ourselves if you wanted to drill and rivet your 90k car lol.
Maybe this question needs to be bumped to Ineos. I would consider it if it is factory installed. If it is installed at dealership, I'll pass and let ppf do its thingCouldn't agree more - especially point 2!!!
Does anyone know with certainty if the fender checker plates are aluminum or plastic for the US Market. Would like to know as anodized aluminum is a proper look, just don't know if regs in the US allow aluminum or not. My 2020 Defender has plastic checker plate, which just looks ok and is too shiny. Always thought about taking some fine wet and dry sandpaper to the top surface of the raised diamonds to cut the glare and give it a better look. DaBullMaybe this question needs to be bumped to Ineos. I would consider it if it is factory installed. If it is installed at dealership, I'll pass and let ppf do its thing
This doesn't give a plastic alternative for anywhere.Does anyone know with certainty if the fender checker plates are aluminum or plastic for the US Market. Would like to know as anodized aluminum is a proper look, just don't know if regs in the US allow aluminum or not. My 2020 Defender has plastic checker plate, which just looks ok and is too shiny. Always thought about taking some fine wet and dry sandpaper to the top surface of the raised diamonds to cut the glare and give it a better look. DaBull
Hi DaveB, Thanks for the clarification. If anyone hears differently, let us know. Interesting to see the aluminum is e-coated vs anodized. Would have preferred anodizing.This doesn't give a plastic alternative for anywhere.
or try Cerakote, a ceramic coating available in many colors, and durable: used on many military weapons on both external and moving partsHi DaveB, Thanks for the clarification. If anyone hears differently, let us know. Interesting to see the aluminum is e-coated vs anodized. Would have preferred anodizing.
E-coating produces a thin paint-like organic coating on the parts whereas anodizing is aluminum oxide, a ceramic-like coating which is much harder and more wear resistant. Perhaps, order checker plate, have e-coating stripped off and properly anodize them a satin black for a proper and more wear resistant look. I used to have aluminum products made that were anodized. Always looked fantastic and lasted forever too. DaBull
Hi Krabby, I think I have seen somewhere that the checker plate is installed with automotive tape and rivets. I am hoping I can just order them and not have the dealer install them until I get them the way I want them first and then look at doing my own install. Hopefully they don't charge me installation labor to simply throw them in the boot. DaBullI am curious how the plates are installed, since they are listed as dealer install. I’m guessing it’s adhesive and if that’s the case it’s probably a doable diy down the road.
I haven’t decided how I feel about them so I will not be ordering them with my build.Hi Krabby, I think I have seen somewhere that the checker plate is installed with automotive tape and rivets. I am hoping I can just order them and not have the dealer install them until I get them the way I want them first and then look at doing my own install. Hopefully they don't charge me installation labor to simply throw them in the boot. DaBull
Adhesive/double sided tape and rivetsI am curious how the plates are installed, since they are listed as dealer install. I’m guessing it’s adhesive and if that’s the case it’s probably a doable diy down the road.
It's a US company selling these:My 2020 Defender has plastic checker plate, which just looks ok and is too shiny.
HI DCPU, Yes I saw these aftermarket checker plates for the new Defender. Still don't understand why they are not anodized and just powder coated.It's a US company selling these:
New Defender Real Alloy Checker Bonnet Plates V2
New Defender Real Alloy Checker Bonnet Plate Updated Version 2 Bring back the classic defender practicality with real alloy checker plate to replace the factory plastic. All new single plate design Full left and right real high quality alloy chequer plates Complete Stainless Steel bolt and...newdefendermods.com
There will be an installation bulletin or whatever INEOS will call these things specifically for the install. It'll get into the public domain sooner or later.I am curious how the plates are installed, since they are listed as dealer install. I’m guessing it’s adhesive and if that’s the case it’s probably a doable diy down the road.
