That's a Nato type socket (female) and powers up anything that you have suitably wired with a male Nato connection. A little like the tow ball electric socket. Same but different. It's a universal type socket used worldwide, more popular in some places than others. (armed forces etc).
will give it a go laterNow - hopefully you can open it. Some owners have had problems with that, even using channel locks - so good to put in a little anti-seize compound
Thank you for this. I may never use mine but if I don't use it until 5 years from now it's only going to be more difficult. The storage compartment on the spare is the same way, better to take it off on a sunny day on your driveway than a cold winter's night.Now - hopefully you can open it. Some owners have had problems with that, even using channel locks - so good to put in a little anti-seize compound
Oh that looks like war crimes were committed! “Unseen methods” - sounds nefarious.Ok just hoping to help here….
When picking Shiitake up from remedial work at the dealer I asked them to show me how to remove this plug cover…
Three employees had a go and then they returned her to the workshop for unseen methods. Here is the result which they are obviously going to replace when supplied with a new one.
I am considering using this plug for direct input from a regulated solar source and wanted to have access. This vehicle was probably manufactured in early 2023 (vin 193) and this plug probably hadn’t been removed until last week.
I suggest anyone wishing to use this, if it’s mounted, needs to remove the cover and probably apply some grease or other anti seize product.
Looks like they put the apprentice onto it with a hammer...Ok just hoping to help here….
Well I saw how big the pipe wrench was that DIDN’T shift it so it was probably better done behind closed doorsLooks like they put the apprentice onto it with a hammer...
Hoping it was a whiskey bung… a self-serve station, maybe?
would it be that unreasonable?Hoping it was a whiskey bung… a self-serve station, maybe?
Use one of those rubber jar openers if you aren't comfortable with padded vice grips or plumbers wrenches..i tried to unscrew mine. no luck
