Error Message "Tyre pressure sensor lost"
Jeremy996
3:24 AM
Late in the day and the dashboard lights up with an amber message "Tyre pressure sensor lost". Checking the displays, you can see that all four are lost, so I guess the sensor receiver is disconnected/toast.
The Grenadier is booked in for diagnostics on the 24th January, (Chandlers are busy and short a technician).
It's this sort of dumb failure that drives my desire for the full workshop manual now. This should not be a big mystery; it's either a wire break or a failed unit, it should not need a trip to the dealer for diagnosis and fixing. You don't get this sort of irritation with a LR110CSW 200Tdi, (just cold, wet feet, deafened, vibrated and a little cramped!)
I'll report back on the fix, when I have one.
The Grenadier is quietly taking the piss; the fault has disappeared after a day and several starts and stops.
I'll have to ring Chandlers to see what to do next. Finding intermittent faults, especially if they aren't currently presented, is a real pain in the ass!
Hi, I took each wheel off in turn for about an hour to put a bit more rust proofing around the exposed parts (Dinitrol 4941 - looks good but probably not necessary - makes me feel better) plus grease around the mating surfaces. Wheel was about 3m max from vehicle. Took it out the garage and all the readings were frozen and looked like defaults. After about 5 miles they all switched to "--" in quick succession and the error message came up. Did not touch it for a few days and took it out again about a week later. One by one the readings came back.
Last weeks I took the right front wheel off for several hours to see how the front bumper can come off but this time kept the wheel very close. No problems with TPMS this time.
Tried to raise this with Ineos CS as a possible software fault but they directed me to dealer. No response from dealer so far.
Richard
Richard
Have you worked out how to take the bumper off yet 🤔. I would like some tips of how to dismantle the U.K./Euro spec bumper Incase I have to fix the small radiator fixings again 👍🏼
Not completely taken it off but have had the centre and right sections loose. Going from memory......
Unscrew the two covers over the joins between the centre and left/right sections. Under here are 6 screws that hold the side section to the centre section. If taking the whole lot off these should probably be left together as you cannot remove the sections piece by piece because of the sensor loom running from from the centre sections and terminating in the side sections behind the coolers.
Next take off the right grill inside the wheel arch behind the cooler. I took out the arch liner and arch extender but I don't think this is necessary now. Lets you have a good look at the steering mechanism. There's a couple of press fixings that are just under the arch liner edge that could probably be removed with the arch liner in place. You'll then see a multi-plug for the sensor loom and a plug for the right bumper indicator plus a few cable guides. These are all fixed to a skeleton bracket that runs from the chassis to the bumper side. Down the side of the cooler there are 3 screws that hold the right section to the metal "real" bumper plate that runs across the three sections in front of the coolers. With a long enough torx drive you can get to these with the bracket in place.
You can then remove the number plate showing 3 male torx bolts and then behind each joint covers are another 2 torx male bolts and these are the main bolts fixing the bumper backer plates to the "real" bumper. I loosened these and the whole thing looked like it would come off once I had disconnected the connectors and presumably done the same on the other side. This is as far as I took it this go. Base camp.
If you remove the 2*6 screws under the join covers and the three torx bolts, the front section will pull forward and hang on the loom allowing you to get to the bash guard upper fixing bolts. Removing this so that I could spray the bash guard black with Dinitrol inside and out was my first aim - looks way better that silver for a donny grey vehicle. I planned to drop the whole bumper off and then Dintrol the whole lot to death but its been so damp and cold here in Aberdeenshire that the surfaces would not dry off even when inside the garage for a few days. Will leave this until later in the year.
A couple of points - there is a little yellow plastic clip on the join covers want to pop off and fall into the bumper. Gave up fishing and one is still in there somewhere but you don't really need it. Hopefully it will still be there when I fully remove the bumper.
The main torx bolts also tend to drop into the bumper easily and you have to fish them out. The access holes are just big enough to get my hand in but there was a few scary moments when my hand would not come out and my phone was on the bench 7 ft away.
Richard
Richard
Thanks. I’ve copied and stored your instructions ready for the next time I need them. 👍🏼
Just had this happen to me tonight; any known fix beyond just waiting it out?
Just had this happen to me tonIt has been reported to INight; any known fix beyond just waiting it out?
INEOS has been informed. Only known solution so far is turn off car over night, then drive in the morning. Error normally disappears about 6o seconds after you started driving, just starting and idling the car is not enough.
Yeah, my dealer claims a software fix is on the way. Appreciate the response!
Same thing happened to my Grenadier, so the fix is let the car sleep overnight? Thanks for saving me 80 mile drive to the dealership
Bonjour,
Alors nous, nous avons beau faire une réinitialisation du TPMS à l'écran à froid le matin, laisser la voiture éteinte toute la nuit, il continue de nous alerter toutes les minutes... pression trop faible, trop hautes...:(
Bonjour,
On peut donc faire un réinitialiser TPMS sur l'écran à froid le matin, laisser la voiture éteinte toute la nuit, il continue de nous avertir toutes les minutes... pression trop basse, trop haute...:(
Bonjour,
Bonjour,
The tyres must be in the right pressure range for the error to clear. Otherwise the error will repeat itself.
Bonsoir,
Nous les avons réglés sur 3 Bars (43,511 psi) et avons un meilleur confort.
Trop ? Pas assez ?
Bonne soirée,
Nous les avons réglés sur 3 barres (43,511 psi) et avons eu un meilleur confort.
Trop? Pas assez ?
Thanks for the tip. Worked perfect.
Had the same problem. Leave the car alone overnight. Start up next day. error disappears. Already mentioned below.
I have just got the same error come up at 7400 ish miles. I had no issues before . Did you find a fix or or this?
Fix is above in the thread and in the quote you replied to. Preventing it happening in the first place - well that's a different question I guess. S/W problem?
