General Engine and cabin air filter
FlyingTexan
6:50 PM
Does anyone have Amazon links for the engine and cabin air filter? I'm seeing 24k miles in the manual, seems like a long time but I grew up farming. Cabin air filter isn't listed in the manual that I can find. How often are you replacing them and do you have links for them?
For the engine air filter search for Mahle LX3985/1. For the cabin air filter it appears to be a unique part ATM.
Cheers
Steve
Cheers
Steve
Hey Dok - I thought there was a Mahle Cabin Filter with a specific number - can be ordered on EBAY. I'll try find the link.
The only after market one I was aware of was A Ryco one but it apparently is thicker so needs a bit of a "push" to fit.
I found this one, but I have no idea where to buy it.
That seller has an unusually high number of Ineos parts available???
The item description is also a little aberrant.
I'd order via the dealer.
How often are you guys pulling your engine filter? I grew up on ranches and we did it every oil change. So 24k seems odd to me.
20k-30k is pretty standard across the automotive industry; a few go beyond 30k.
The best answer is "it depends". Driving conditions, as well as whether or not you have the RAI will make a notable difference in when the filter actually needs to be replaced
I picked up a cabin filter from my dealer yesterday. I noticed the new filter is slightly different. There's no gray foam on one side of the filter. The part numbers are also different.
The top filter is the original filter and the bottom if the replacement.
Interesting the one that came fitted to my car (May23 build) is the bottom filter in your pic. It also has an older date on the right. Old parts stock perhaps?
Cheers
Steve
