DVA Mechanics - Latest Cable --> DTP to Weather Pack (18”)
DVA Mechanics
Supporting Vendor
7:30 PM
Atlanta, GA, USA
Easily connect your accessories to the Ineos Grenadier’s rooftop power ports without cutting or modifying your wiring! This 18-inch adapter cable features a Male DTP connector on one end and a Male Weather Pack 2-Pin connector on the other, allowing seamless integration of Weather Pack-equipped accessories with your Grenadier’s factory power connection.
No more splicing or custom wiring—just plug and play. Whether you’re adding light bars, work lights, auxiliary power, or other off-road accessories, this adapter lets you maintain a clean, professional installation without compromising durability or weather resistance.
Key Features:
✅ Direct Fit for Ineos Grenadier – Plugs into the factory rooftop DTP power port
✅ Weather Pack 2-Pin Connector – Compatible with accessories using a female Weather Pack plug
✅ No Cutting Required – Preserve your accessory’s original wiring and avoid permanent modifications
✅ Plug & Play Installation – Saves time and effort compared to crimping or splicing
✅ 18” Length for Flexibility – Offers just enough slack for a tidy, organized connection
✅ Built for Harsh ConditionsWeatherproof connectors ensure reliability in off-road and outdoor environments
If you’re running Weather Pack-equipped lights or accessories on your Grenadier, this adapter is the easiest and cleanest way to get them connected without modifying factory wiring.
Key Features:
Any link for these?
Any link for these?
Here you go!
Here you go!
That's great. Thanks. :-)
