I say it could, but it won’t be mine, I’ve already driven past it once, have no problem doing it againYeah mate but can she do Gunshot Creek eh
The long drop though?I say it could, but it won’t be mine, I’ve already driven past it once, have no problem doing it again![]()
Sorry that’s what I meant. That drop is only for 20 year olds in old patrols and hiluxes.The long drop though?
Luckily they're all restricted to social media!Sorry that’s what I meant. That drop is only for 20 year olds in old patrols and hiluxes.![]()
The HDC does brake the wheels individually in regard to the torque they can deliver. A human driver is not able to do so as we only have one pedal to brake. Engine brake can not do this in such a sophisticated way neither. To be fair, the incline has to be very steep and slippery to get the full advantage. Most drivers probably will never try to make such an approach as it might well won't work out well.On my Grenadier event last weekend, the Dutch instructor, a "real" 4x4 expert, told us the Hill Descent Control was just faster and more accurate than any human being could be!
I repeat, the guy is a real expert!
I drive the Petrol Version, and I can tell you with HDC and without HDC, but Low Gear, middle Diff blocked, in manuell gear1, the Grenny is so slow, that you want to go in gear 2…. In direct comparism to the Diesel Version on same track, was no difference ….Low range in the Grenadier is 2.5:1 - and in the gas Grenadier, the engine, with this low range ratio, does not provide great braking while going down steep hills off-road. I'm sure you are right that the diesel does a better job holding down the speed.
Ineos likes to point out that the 2.5:1 ratio lets you go pretty fast in low-range, but I don't need to go fast in low range. I need low range to keep me moving slow while descending steep rocky terrain. With an 8-speed transmission, the best low range ratio for my use is 4.0:1. With this low of a low-range, I can still go plenty fast in 8th gear in low range, but I can also crawl super-slow down a steep slope without touching the brakes, and without using HDC.
In practical terms, it's all down to the use case of the vehicle. The Grenadier wasn't designed as a rock crawler (although it won't be bad at it), unlike the jeep wrangler rubicon with its 4.1 ratio.Low range in the Grenadier is 2.5:1 - and in the gas Grenadier, the engine, with this low range ratio, does not provide great braking while going down steep hills off-road. I'm sure you are right that the diesel does a better job holding down the speed.
the grenadier has a very good crawl ratio (ie the gearing of low low is 56 to 1 the petrol i think is fractionally betterIn practical terms, it's all down to the use case of the vehicle. The Grenadier wasn't designed as a rock crawler (although it won't be bad at it), unlike the jeep wrangler rubicon with its 4.1 ratio.
However when I was in Albania, my low range gearing was more suited to the mountain switchbacks of the Theth route than the JL rubicon that accompanied me. The 1st in the Grenadier is very low, so I was between 2nd and 3rd low range most of the time, but it wasn't too low and Jerky. The Jeep was in the awkward area between ranges range, not having the legs to stay in L on the straight gravel sections where speeds increased.
I think 2.5 to 1 is a more all-round low range ratio suited to the Grenadiers all purpose use case. It's better in sand for instance, but still plenty low enough to push a 3.5ton trailer uphill in reverse with the brakes on... don't ask me how I know this..
The wranglers aren't designed with all the utility duties of the Gren in mind, so can dedicate themselves to one thing, which is crawling rocks like nothing else can imagine
but the crawl speed is nearly the same due to the lower idle speed of the diesel.Diesel is 56:1 (or more precisely 56.4:1)
Petrol is not quite as good at 53.8:1
I did not find the source for this, but it should be correct. Maybe someone here recalls where the actual crawl speed has been published. Probably in one of the off-road magazines.
but isn't the diesels idle lower than the petrols?I think you mean the lower engine idle of the petrol.
Both the diesel and the petrol have a crawl speed of 2km/h.
That's for non-experienced and for automatic transmissions
Hi-Low with manual transmission it is very simple with double clutching. Autobox is difficult and I don't recommend trying. Automatic does it more easily at slow speed than standstill.
Center diff lock doesn't care about speed, just wheel spin. I have engaged it on Land Rovers at 80 km/h.
Still early days for me in discovering the tuning on the ZF 8HP76 in my diesel M1 but it does seem quite smart. I was pleasantly surprised when I first hooked up my offroad hybrid camper and coasted downhill out of my street. The auto sensed the overrun because I was being pushed by the weight of the camper. It downshifted then held a low gear to increase driveline braking. An older auto would have upshifted in the same closed-throttle coasting conditions.Auto transmissions have changed dramatically since them olden days when they provided little compression braking. With modern lock-up torque converters you'd think they'd have solved the issue by now but I have no idea. I drive THM350s and THM400s so I'm truly ig'nant.
Mine drops to 3rd or 4th down the steep hill from my house towards a hwy.Still early days for me in discovering the tuning on the ZF 8HP76 in my diesel M1 but it does seem quite smart. I was pleasantly surprised when I first hooked up my offroad hybrid camper and coasted downhill out of my street. The auto sensed the overrun because I was being pushed by the weight of the camper. It downshifted then held a low gear to increase driveline braking. An older auto would have upshifted in the same closed-throttle coasting conditions.
