CTEK CT5
Thenextchapter
11:02 PM
New Zealand
I have to leave my very much loved Grenadier in the garage for extended periods (sometimes), and looking to maintain the battery while away. Given the EFB and start-stop optimization of our INEOS batteries, looking at the CTEK CT5 as an option. Anyone got any experience with this specific maintenance charger? In a related question, would it be best to connect the charger to a) the auxiliary battery which will charge the starter battery via the CTEK 120S pulse charge feature, b) to the starter battery(see note 1) or c) both starter and auxiliary. This second question maybe for CTEK support, but asking here in case someone already knows the answer. I will ask CTEK as well. Thanks
Note (1). To allow the battery management system (BMS) to correctly determine the State of Charge (SoC) for the starter battery, option b) would have the wiring connected to the jumpstart post in the engine bay.
Note (2). Old reference of CTEK D120 corrected to CTEK 120S.
What is CTEK D120? Isn't it 120 S from factory?
My factory CTEK lets the auxillary battery only charge the starter batterie when this is under ~ 12,3 V, otherwise it is disconnected. So a) wouldn't work (.... to keep the starter full at all times)
I use the Victron charger connected to the starter battery along with a Victron battery monitor on each battery. One app for all devices. Works well.
Ooops, I meant the factory CTEK 120S. Fixed that in the original post.
I think most people will choose option a) as it will definitely charge the starter battery, but let’s see.
I have a Victron smart monitor in my other truck. So, not sure why I did not think of this.:-) Nice idea to install one on the auxiliary battery given the dash does not display voltage of SoC for the auxiliary.
Will look into the Victron charger. Thanks
Manual says: trickle charge between 11.5 - 12.6 V of starter batterie, my own observation is 12,3 V . But you will see :)
Ok, a bit of an update based on some further research.
1) Wrote to CTEK support. Will see what they say. But on their website they have a document giving advice when the charger connected to the service battery (here) and a different document with advice when connecting to the starter battery (here). Picture below as an example. It is a little hard to determine if the connection to the starter or service battery is preferred, but looks like they are recommending the starter battery. Their exact words are:
  • Connecting it to the starter battery is preferred for storage reasons or when you have loads applied to both starter and service battery.
  • Connecting it to the service battery is preferred when only the service battery is in use.
2) Based on another post in the forum by (Lollo050968), it is recommended not to trickle charge the battery. I looked at the MOLL website, and found a data-sheet for a battery that is very similar to the one in the Grenadier. The data-sheet is (here). A couple of useful things in the data-sheet. Recommended charge voltage is 14.4volts and recommended charge current is 11 Amps, but this would be 10.5 Amps for our batteries (as they at 105 Ahr). But I am less worried about charging, and more about maintaining. So, maybe this is less important to me.
3) The Victron Smart charger has a storage mode which according to their manual states; "The battery voltage is maintained at the configured storage voltage, which is slightly reduced compared to the float voltage to minimise gassing and extend battery life whilst the battery is unused and on continuous charge". While the CTEK MXS10 also has a maintenance mode based but is based on a pulse function. And from their manual; "Maintaining the battery at 95–100% capacity. The charger monitors the battery voltage and gives a pulse when necessary to keep the battery fully charged".
For simplicity, just run your charger into the rear cigarette lighter socket and leave the overhead power switch on. Works perfectly.
Hello from Germany!
As I am in the same situation and have to leave my Grenny alone for a few weeks at a time, I bought a Victron IP22 12/30 and fitted it to the starter battery.
After a first test run yesterday, it did exactly what I expected and charged both batteries.
Now the charger switches to storage mode and keeps the voltage at the optimum level.
I can easily check all the data via the Victron Connect app.
Translated with DeepL.com (free version)
After I only had a starter battery charge level of 38%, I connected the charger CTEK MXS 10 to the input of the CTEK 120S, which comes from the positive terminal of the starter battery. That way I didn't have to half dismantle the car to get to the starter battery. It works great, starter battery and auxiliary battery are fully charged after a few hours.
I like this idea. I may use this for a solar blanket.
Me too so watching this space 😉
I’m in a slight quandary now too with a cheapie air compressor that I have bought as a stand in until I decide on what to do more permanently. ($50 cheap so only needs to last a week on an upcoming trip)
But what has me thinking because of other posts regarding current draw of these devices is whether the cigarette socket is wired to the sufficient needs for both solar input and my compressor output?
And if so I’m presuming (but shouldn’t perhaps) that adequate fusing is also built in?
I’ve been pondering this for a while and been lazy in not looking at RokDr’s guide…
Anyway just thought I’d engage the oracles on here 😁👍🏼
After 12 years my cheap 12V compressor is still working. It may not have the performance of my ARB but it inflates tires! Just clip it to the battery post under the bonnet.
Both batteries charge/maintain?
Yes - or at least it appears to me that it does. Certainly fills the starter battery and I can't see why that wouldn't also feed through the SmartPass to the auxiliary battery. Can't confirm though as I didn't have a monitor on the aux battery when I was doing it this way. I will try it next weekend now that I have installed a Smart Shunt and check that it does feed both.
Now confirmed. Charge does pass to the Aux battery via the SmartPass.
That's correct. The Smartpass will cut in to start charging the Aux battery once it sees more than 13.1 v for 5 seconds. In my testing the other week, my solar panel running through a Victron regulator was able to wake up the smartpass and start charging both batteries. Lights on top of the Smartpass will indicate this and I'll be putting explanations for them in the next edition of the manual as it took me a while to find the hard copy smartpass manual I had filed in an obscure place LOL.
Steve
So, could you also fit a solar panel with MPPT to the EXT3 roof connector, flip on both overhead power & EXT3, and charge the batteries in the same manner?
