Cryptic Sticker
Here is my sticker but I noticed that the following codes are missing from my sticker:
EMI - Power Heated Exterior Mirrors
ETK - Tow hitch Electrics
EWH - Heated Windscreen Jets
IAY - Lockable Central Storage
IWC - Napa Leather Pack
PPP - Rough Pack
PPW - Power Take off 400W
PPP - Rough Pack
Thanks for that @AngusMacG. Its certainly looking like that not all build options are captured on the sticker.
Yes. I've noticed that my sticker does not indicate my Rear Side Panels (GBA) or my Heated Front Seats (ISF).
I know I said I'd refrain from posting the answers and if I'm honest, I'm itching to!!!
...but I thought it's worth noting Qs like yours @Michael H.... as an example, regarding ISF above, do you have ISL or ISO on the sticker? There's a relationship between some. Some are obvious, some maybe not so and may refer to your market ;)
Have you guys worked out the point of the stickers yet? I know for a fact that @Jean Mercier should know....
Thanks for coming out of retirement, Paddy. 🙂 I do not have ISL or ISO on my sticker, as my seats aren’t leather. 😉
While I’ve got you, can you point me in the right direction to get more information on spring classes. I have CSD and CSG, and I’d like to get further details of what Class 2 and Class 1 mean. 🙂
Please note that I cannot personally verify the below loads as accurate. However, I believe your own in depth google search, or technical requests for replacement springs will reap the same/similar results. Also, note that not all of these options will be available/homologated, I am assuming here that they're everything the relevant manufacturer has potentially for the application, including SW/UW/QM/DCC(??)
Front Axle Spring Class 1CSC1345 - 1417; 27N/mm
Front Axle Spring Class 2CSD1417 - 1470 kg; 28,5N7mm
Front Axle Spring Class 3CSE1470 - 1523 kg; 30N/mm
Front Axle Spring Class 4CSF1523 - 1576 kg; 32N/mm
Front Axle Spring Class 5CSJ1576 - 1629 kg; 33,7 N/mm
Rear Axle Spring Class 1CSG1299 - 1355 kg; 26/35/68N/mm
Rear Axle Spring Class 2CSH1355 - 1411 kg; 27,5/38/71N/mm
Rear Axle Spring Class 3CSI1411 - 1467 kg; 29,5/40/74N/mm
Rear Axle Spring Class 4CSK1467 - 1523 kg; 31/42/74 N/mm
Rear Axle Spring Class 5CSL1187 - 1243 kg; 23/31/54N/mm
Rear Axle Spring Class 6CSM1243 - 1299 kg; 24,5/33/58 N/mm
Thanks, Paddy. It's all coming together nicely now …
Purpose...
As you probably know kits of vehicle specific parts are delivered to the line just in time. The worker will scan the vehicle and kit to confirm the requirement.
The label gives a human readable double check.
Likewise the quality control team have a robust checking system.
It's not unheard of to 50 cars off the end of the line all with the wrong bumpers where someone has messed up the sequence. Sometimes deliberately to get some Saturday morning overtime.
I glad to see you can't resist temptation @Paddy :) :)
Thank you for the spring info. I'll add it to the table in Post #15. Thank you too @Michael H. You've saved me the trouble of chasing down that post with the spring colour codes.
My guess is its a fancier less human readable version of the old paint/trim code sticker and possibly a security/cross check.
Steve
I've consolidated the listed codes.
If you add something, I suggest to copy the list to a new posting and to insert yours in the correct order and the same format.
To insert a code, you have to be in edit mode (of course).
- Just place the cursor in front of the right position and press enter.
- insert the code, colon and text
- The numbering will be updated automatically.
  1. CSC: Front Axle Spring Class 1, 1345 - 1417; 27N/mm
  2. CSD: Front Axle Spring Class 2, 1417 - 1470 kg; 28,5N7mm
  3. CSE: Front Axle Spring Class 3, 1470 - 1523 kg; 30N/mm
  4. CSF: Front Axle Spring Class 4, 1523 - 1576 kg; 32N/mm
  5. CSG: Rear Axle Spring Class 1, 1299 - 1355 kg; 26/35/68N/mm
  6. CSH: Rear Axle Spring Class 2, 1355 - 1411 kg; 27,5/38/71N/mm
  7. CSI: Rear Axle Spring Class 3, 1411 - 1467 kg; 29,5/40/74N/mm
  8. CSJ: Front Axle Spring Class 5, 1523 - 1576 kg; 33.7N/mm
  9. CSK: Rear Axle Spring Class 4, 1467 - 1523 kg; 31/42/74 N/mm
  10. CSL: Rear Axle Spring Class 5, 1187 - 1243 kg; 23/31/54N/mm
  11. CSM: Rear Axle Spring Class 6, 1243 - 1299 kg; 24,5/33/58 N/mm
  12. DDA: Front/Rear Diff Locks
  13. DDG: Diesel Water Separator
  14. DDH: Heated Blow-By Diesel Engine
  15. DDN: Petrol Fuel Filter
  16. EDC: Spare Wheel Cover (plastic clip-in solution)
  17. EHF: Load Bay Tub Quartermaster
  18. EMI: Power Heated Exterior Mirrors
  19. ETA: Vertical Towing Interface
  20. ETC:
  21. ETH: Fire Extinguisher
  22. ETK: Class III 1-7/8" NAS Tow Hitch and Electrics
  23. ETN: Vertical Towing Interface /( Towing Plate Front
  24. EWH: Heated Windscreen Washer Jets
  25. EWK: Safari Windows
  26. EWO: Heat Reflective Privacy Glass
  27. EYK: Exterior Utility Belt / Load Bay Mounting Bar Quartermaster
  28. EYL: Bump Strips
  29. EZC: Light Bar Provision (EE); Package Protection
  30. FPB: indeed Sela Green Paint (you know this)
  31. FPC: Eldoret Blue Paint
  32. FPD: Scottish White Paint
  33. FPF: Inky Black Paint
  34. FPG: Shale Blue Paint
  35. FPI: Britannia Blue Paint
  36. FPJ: Inky Black Contrast Roof
  37. FPK: Scottish White Contrast Roof
  38. FPL: Magic Mushroom Paint
  39. FPM: Donny Grey Paint
  40. FPN: Queen's Red Paint
  41. FPP: Sterling Silver Paint
  42. FQP: Halo Red Chassis Finish
  43. FQQ: Rhino Grey Chassis Finish
  44. FQS: Black Chassis Finish
  45. GBA: Rear Side Panels
  46. IAY: Central Storage Box, Lockable Central Storage
  47. IBC: Seatbelt Reminder Rear Seats
  48. IHC: Rear passenger heating/cooling
  49. ILC: Premium Sound System
  50. IOI: Compass with Altimeter (not on sticker)
  51. IPA: 12V socket-outlet; centre console
  52. IPH: USB Power Plugs; 2nd seat row
  53. IPP:
  54. IPQ: 12V socket in trunk
  55. ISA: Utility Trim Fabric Seats
  56. ISF: Heated Front Seats
  57. ISI: Isofix & I-SIZE - Rear Seats
  58. ISL: Leather Trim - Black
  59. ISO: Leather Trim - Grey/Black
  60. ISS: Isofix & I-SIZE - Rear Seats
  61. IWC: Napa Leather Drivers Pack
  62. IWH: Saddle Leather Drivers Pack
  63. JTA: Heavy Duty Flooring
  64. JTC: Carpet Flooring
  65. JTD: Interior Standard Trim
  66. PPC: Aux Charge Points
  67. PPP: Rough Pack
  68. PPT: Trialmaster (EU)
  69. PPW: 400w Inverter / Power Take off 400W
  70. PPZ: Smooth Pack
  71. SSN: Additional second warning vest
  72. SSO: Additional Second Warning Triangle / Road Side Emergency Kit
  73. SSR: Road Side Emergency Kit plus (probably mandatory here, because I didn't ask for it!)
  74. TTB: Advanced Anti Theft Immobiliser
  75. UAA: Park Assist Front (In your table USS? typo?) (PDC)
  76. UAE: Trailer Stability Assist / Trailer Sway Control (TSC)
  77. UAG: Rear View Camera
  78. UAL: High Load Aux Switch Panel and Elec Prep
  79. UAO:
  80. USS: Can you send a photo of this code?
  81. VAR: Roof Cross Bars (not on sticker, because removable)
  82. VAU: Access Ladder
  83. VAV: Spare Wheel Lockable Storage Box
  84. VCH: Carpet Floor Mats
  85. VCZ: Off-Road Recovery Kit (not on sticker, because removable)
  86. VDA: Aux Battery
  87. VDN: Locking Wheel Nuts
  88. VDP: Raised Air Intake
  89. VED: Integrated Heavy Duty Winch
  90. VEJ: Rubber Floor Mats
  91. VEN: Smokers Pack
  92. VET: Skid plate Rear
  93. VFP: Interior Utility Rails
  94. VGC:
  95. VGI: Load Bay Utility Rails Quartermaster
  96. WBP: 17" Steel Wheel Black (you know this)
  97. WBQ: 17" Alloy Wheel, Grey Metallic Matt Finish
  98. WBR: 18" Steel Wheel
  99. WBS: 18" Alloy Wheel.
  100. WBT: Bridgestone all terrain tyre
  101. WBU: BF Goodrich KO2 All terrain tyre
@emax: sorry, added some from your list to my list - was less work...
and here it is:
CodeDescriptionRemarks
1​
CSCFront Axle Spring Class 11345 - 1417; 27N/mm
2​
CSDFront Axle Spring Class 21417 - 1470 kg; 28,5N7mm
3​
CSEFront Axle Spring Class 31470 - 1523 kg; 30N/mm
4​
CSFFront Axle Spring Class 41523 - 1576 kg; 32N/mm
5​
CSGRear Axle Spring Class 11299 - 1355 kg; 26/35/68N/mm
6​
CSHRear Axle Spring Class 21355 - 1411 kg; 27,5/38/71N/mm
7​
CSIRear Axle Spring Class 31411 - 1467 kg; 29,5/40/74N/mm
8​
CSJFront Axle Spring Class 51576 - 1629 kg; 33,7 N/mm
9​
CSKRear Axle Spring Class 41467 - 1523 kg; 31/42/74 N/mm
10​
CSLRear Axle Spring Class 51187 - 1243 kg; 23/31/54N/mm
11​
CSMRear Axle Spring Class 61243 - 1299 kg; 24,5/33/58 N/mm
12​
DDAFront/Rear Diff Locks
13​
DDGDiesel Water Separator
14​
DDHHeated Blow-By Diesel Engine
15​
DDNPetrol Fuel Filter
16​
EDCSpare Wheel Cover (plastic clip-in solution)
17​
EHFLoad Bay Tub Quartermaster
18​
EMIPower Heated Exterior Mirrors
19​
ETAVertical Towing Interface Towing Mounting Plate (Front)
20​
ETCFixed Towball and Electrics
21​
ETDNATO Pintle Tow Hitch and Electrics
22​
ETHFire Extinguisher
23​
ETI50mm Towball & Jaw and Electrics
24​
ETKClass III 1-7/8" NAS Tow Hitch and Electrics
25​
ETNTowing Plate Front
26​
ETSClass III 2” NAS Tow Hitch and Electrics
27​
EWHHeated Windscreen Washer Jets
28​
EWKSafari Windows
29​
EWOHeat Reflective Privacy Glass
30​
EYKExterior Utility Belt / Load Bay Mounting Bar Quartermaster
31​
EYLBump Strips
32​
EZCLight Bar Provision (EE); Package Protection
33​
FPBSela Green Paint
34​
FPCEldoret Blue Paint
35​
FPDScottish White Paint
36​
FPFInky Black Paint
37​
FPGShale Blue Paint
38​
FPIBritannia Blue Paint
39​
FPJInky Black Contrast Roof
40​
FPKScottish White Contrast Roof
41​
FPLMagic Mushroom Paint
42​
FPMDonny Grey Paint
43​
FPNQueen's Red Paint
44​
FPPSterling Silver Paint
45​
FQATunic RedCONTRAST REAR DOOR
46​
FQBEmergency OrangeCONTRAST REAR DOOR
47​
FQDTunic RedCONTRAST NOSE
48​
FQEEmergency OrangeCONTRAST NOSE
49​
FQPHalo Red Chassis Finish
50​
FQPRedCONTRAST LADDER FRAME
51​
FQQRhino Grey Chassis Finish
52​
FQQGreyCONTRAST LADDER FRAME
53​
FQSBlack Chassis Finish
54​
FQSBlackCONTRAST LADDER FRAME
55​
FWKsafari windows?- typing error?
56​
GBARear Side Panels
57​
IAYCentral Storage Box, Lockable
58​
IBCSeatbelt Reminder Rear Seats
59​
ICHRear passenger heating/cooling
60​
ILCPremium Sound System
61​
IOICompass with Altimeter (not on sticker)
62​
IPA12V socket-outlet; centre console
63​
IPHUSB Power Plugs; 2nd seat row
64​
IPP
65​
IPQ12V socket in trunk
66​
ISAUtility Trim Fabric Seats
67​
ISFHeated Fornt Seats
68​
ISIIsofix & I-SIZE - Rear Seats
69​
ISLLeather Trim - Black
70​
ISOLeather Trim - Grey/Black
71​
ISSIsofix & I-SIZE - Rear Seats
72​
IWCNappa Leather Driver's Pack
73​
IWHSaddle Leather Driver's Pack
74​
JTAHeavy Duty Utility Flooring with Drain Valves
75​
JTCCarpet Flooring
76​
JTDInterior Standard Trim
77​
PPCAuxiliary Charge Points
78​
PPPRough PackDifferential Locks Front & Rear/BFGoodrich All-Terrain T/A KO2 Tyre
79​
PPTTrialmaster (EU)
80​
PPW400w Inverter / Power Take off 400W
81​
PPZSmooth PackRear-View Camera/Park Assist Front (PDC)/Central Stowage Box, Lockable/Puddle Lamps and Ambient Door Lighting
82​
S12Rear Side Windows
83​
SSNAdditional second warning vest
84​
SSOAdditional Second Warning Triangle
85​
SSQRoad Side Emergency Kit
86​
SSRRoad Side Emergency Kit Plus
87​
TTBAdvanced Anti Theft Immobiliser
88​
UAAPark Assist Front (PDC)
89​
UAETrailer Stability Assist / Trailer Sway Control (TSC)
90​
UAGRear View Camera
91​
UALHigh Load Auxiliary Switch Panel & Electrical Preparation
92​
UAO
93​
UAR6-Foot Roof Rack
94​
USStyping error?
95​
VAAFull-length Roof Rack
96​
VABSpare Wheel Carrier
97​
VAITool Bracket
98​
VAJSpot Light Bracket
99​
VALSurfboard Carrier
100​
VAOBike Carrier
101​
VAQHi-Lift Jack Mount
102​
VARRoof Cross Bars (not on sticker, because removable)
103​
VASSki/Snowboard Carrier
104​
VAUAccess Ladder
105​
VAVSpare Wheel Lockable Storage Box
106​
VAWSide Runners
107​
VAXChecker Plates
108​
VAY40" Front LED Light Bar (incl. mounting brackets)
109​
VBKRemovable Winch with Tow Mounting Kit - 3.5 Tonnes
110​
VBMBatwing Side Awning
111​
VCG
112​
VCHCarpet Floor Mats
113​
VCIFoldable Tailgate Camp Table
114​
VCMCollapsible Luggage Organiser
115​
VCOLuggage Retention Net - Floor
116​
VCUCargo Load Straps
117​
VCYHeavy Duty Seat Covers - Front
118​
VCZOff-Road Recovery Kit (not on sticker, because removable)
119​
VDAAuxiliary Battery
120​
VDJRock Sliders
121​
VDNLocking Wheel Nuts
122​
VDPRaised Air Intake
123​
VDQRaised Air intake Cyclone Pre-Cleaner
124​
VDVSand Ladder Flat Mounting Brackets
125​
VEDIntegrated Heavy Duty Winch - 5.5 Tonnes
126​
VEJRubber Floor Mats
127​
VEMNational Flag Plaque - UK
128​
VENSmokers Pack
129​
VETSkid plate Rear
130​
VEVNational Flag Plaque USA
131​
VFAQuick Release Tie-Down Rings (x4)
132​
VFKGas Bottle Holder for Roof Rack
133​
VFOUtility Cargo Barrier - Half-height
134​
VFPInterior Utility Rails
135​
VFSFull-height Loadspace Divider
136​
VFTLoadspace Partition Net
137​
VFYCargo Management System
138​
VGCtyping error?
139​
VGGTrailer Hitch Bike Rack
140​
VGILoad Bay Utility Rails Quartermaster
141​
VGJCargo Box
142​
VGKLoad Mounting Brackets for Roof Rack
143​
VGLAdjustable Load Holder
144​
VGMKayak Mount J-Style
145​
VGNKayak Mount Saddles
146​
VGORoof Tie-Down Rings
147​
VGPRotopaX(TM) Mounting Bracket
148​
VGQFolding Aerial Mount
149​
VGRHeavy Duty Spade
150​
VGSLockdown Security Cable
151​
VGTSand Ladder Side Mounting Brackets
152​
VGWHeavy Duty Seat Covers - Rear
153​
VGZPioneer Accessory Bar
154​
WBP17" Steel Wheel
155​
WBQ17" Alloy Wheel, Grey Metallic Matt Finish
156​
WBR18" Steel Wheel
157​
WBS18" Alloy Wheel.
158​
WBTBridgestone all terrain tyre
159​
WBUBFGoodrich All-Terrain T/A KO2 Tyre
The question is: Can others still contribute to your list as a consolidation?
How easy is it to maintain alphabetical order and sequential numbering at the same time without making extensive edits?
Has anyone worked out what IPP, VCG and UAO mean? @Paddy ?
And I agree that VGC is a typo @csjeeper and probably my mistake originally.
Steve
I made my list with excel. It's quite easy to sort the entries in alphabetical order (simply select the columns "Code", "Description" and "Remarks", activate "filter" under "Data" and sort "Code" in ascending order).
I hope I was clear enough; otherwise please ask.
It's easy to cut and paste the table from the relevant post then to edit click in a cell and you will get a menu that allows you to add rows, columns and headers or delete the table.
A couple of blanks in @csjeeper's table filled in below. But its a lot easier to do in excel!
Steve
1CSCFront Axle Spring Class 11345 - 1417; 27N/mm
2CSDFront Axle Spring Class 21417 - 1470 kg; 28,5N7mm
3CSEFront Axle Spring Class 31470 - 1523 kg; 30N/mm
4CSFFront Axle Spring Class 41523 - 1576 kg; 32N/mm
5CSGRear Axle Spring Class 11299 - 1355 kg; 26/35/68N/mm
6CSHRear Axle Spring Class 21355 - 1411 kg; 27,5/38/71N/mm
7CSIRear Axle Spring Class 31411 - 1467 kg; 29,5/40/74N/mm
8CSJFront Axle Spring Class 51576 - 1629 kg; 33,7 N/mm
9CSKRear Axle Spring Class 41467 - 1523 kg; 31/42/74 N/mm
10CSLRear Axle Spring Class 51187 - 1243 kg; 23/31/54N/mm
11CSMRear Axle Spring Class 61243 - 1299 kg; 24,5/33/58 N/mm
12DDAFront/Rear Diff Locks
13DDGDiesel Water Separator
14DDHHeated Blow-By Diesel Engine
15DDNPetrol Fuel Filter
16EDCSpare Wheel Cover (plastic clip-in solution)
17EHFLoad Bay Tub Quartermaster
18EMIPower Heated Exterior Mirrors
19ETAVertical Towing Interface Towing Mounting Plate (Front)
20ETCFixed Towball and Electrics
21ETDNATO Pintle Tow Hitch and Electrics
22ETHFire Extinguisher
23ETI50mm Towball & Jaw and Electrics
24ETKClass III 1-7/8" NAS Tow Hitch and Electrics
25ETNTowing Plate Front
26ETSClass III 2” NAS Tow Hitch and Electrics
27EWHHeated Windscreen Washer Jets
28EWKSafari Windows
29EWOHeat Reflective Privacy Glass
30EYKExterior Utility Belt / Load Bay Mounting Bar Quartermaster
31EYLBump Strips
32EZCLight Bar Provision (EE); Package Protection
33FPBSela Green Paint
34FPCEldoret Blue Paint
35FPDScottish White Paint
36FPFInky Black Paint
37FPGShale Blue Paint
38FPIBritannia Blue Paint
39FPJInky Black Contrast Roof
40FPKScottish White Contrast Roof
41FPLMagic Mushroom Paint
42FPMDonny Grey Paint
43FPNQueen's Red Paint
44FPPSterling Silver Paint
45FQATunic RedCONTRAST REAR DOOR
46FQBEmergency OrangeCONTRAST REAR DOOR
47FQDTunic RedCONTRAST NOSE
48FQEEmergency OrangeCONTRAST NOSE
49FQPHalo Red Chassis FinishCONTRAST LADDER FRAME
51FQQRhino Grey Chassis FinishCONTRAST LADDER FRAME
53FQSBlack Chassis FinishCONTRAST LADDER FRAME
56GBARear Side Panels
57IAYCentral Storage Box, Lockable
58IBCSeatbelt Reminder Rear Seats
59ICHRear passenger heating/cooling
60ILCPremium Sound System
61IOICompass with Altimeter (not on sticker)
62IPA12V socket-outlet; centre console
63IPHUSB Power Plugs; 2nd seat row
64IPPPower Inverter 400w
65IPQ12V socket in trunk
66ISAUtility Trim Fabric Seats
67ISFHeated Fornt Seats
68ISIIsofix & I-SIZE - Rear Seats
69ISLLeather Trim - Black
70ISOLeather Trim - Grey/Black
71ISSIsofix & I-SIZE - Rear Seats
72IWCNappa Leather Driver's Pack
73IWHSaddle Leather Driver's Pack
74JTAHeavy Duty Utility Flooring with Drain Valves
75JTCCarpet Flooring
76JTDInterior Standard Trim
77PPCAuxiliary Charge Points
78PPPRough PackDifferential Locks Front & Rear/BFGoodrich All-Terrain T/A KO2 Tyre
79PPTTrialmaster (EU)
80PPW400w Inverter / Power Take off 400W
81PPZSmooth PackRear-View Camera/Park Assist Front (PDC)/Central Stowage Box, Lockable/Puddle Lamps and Ambient Door Lighting
82S12Rear Side Windows
83SSNAdditional second warning vest
84SSOAdditional Second Warning Triangle
85SSQRoad Side Emergency Kit
86SSRRoad Side Emergency Kit Plus
87TTBAdvanced Anti Theft Immobiliser
88UAAPark Assist Front (PDC)
89UAETrailer Stability Assist / Trailer Sway Control (TSC)
90UAGRear View Camera
91UALHigh Load Auxiliary Switch Panel & Electrical Preparation
92UAOADAS 1
93UAR6-Foot Roof Rack
95VAAFull-length Roof Rack
96VABSpare Wheel Carrier
97VAITool Bracket
98VAJSpot Light Bracket
99VALSurfboard Carrier
100VAOBike Carrier
101VAQHi-Lift Jack Mount
102VARRoof Cross Bars (not on sticker, because removable)
103VASSki/Snowboard Carrier
104VAUAccess Ladder
105VAVSpare Wheel Lockable Storage Box
106VAWSide Runners
107VAXChecker Plates
108VAY40" Front LED Light Bar (incl. mounting brackets)
109VBKRemovable Winch with Tow Mounting Kit - 3.5 Tonnes
110VBMBatwing Side Awning
111VCGUnder Seat Storage Compartment - Rear
112VCHCarpet Floor Mats
113VCIFoldable Tailgate Camp Table
114VCMCollapsible Luggage Organiser
115VCOLuggage Retention Net - Floor
116VCUCargo Load Straps
117VCYHeavy Duty Seat Covers - Front
118VCZOff-Road Recovery Kit (not on sticker, because removable)
119VDAAuxiliary Battery
120VDJRock Sliders
121VDNLocking Wheel Nuts
122VDPRaised Air Intake
123VDQRaised Air intake Cyclone Pre-Cleaner
124VDVSand Ladder Flat Mounting Brackets
125VEDIntegrated Heavy Duty Winch - 5.5 Tonnes
126VEJRubber Floor Mats
127VEMNational Flag Plaque - UK
128VENSmokers Pack
129VETSkid plate Rear
130VEVNational Flag Plaque USA
131VFAQuick Release Tie-Down Rings (x4)
132VFKGas Bottle Holder for Roof Rack
133VFOUtility Cargo Barrier - Half-height
134VFPInterior Utility Rails
135VFSFull-height Loadspace Divider
136VFTLoadspace Partition Net
137VFYCargo Management System
138VGCtyping error?
139VGGTrailer Hitch Bike Rack
140VGILoad Bay Utility Rails Quartermaster
141VGJCargo Box
142VGKLoad Mounting Brackets for Roof Rack
143VGLAdjustable Load Holder
144VGMKayak Mount J-Style
145VGNKayak Mount Saddles
146VGORoof Tie-Down Rings
147VGPRotopaX(TM) Mounting Bracket
148VGQFolding Aerial Mount
149VGRHeavy Duty Spade
150VGSLockdown Security Cable
151VGTSand Ladder Side Mounting Brackets
152VGWHeavy Duty Seat Covers - Rear
153VGZPioneer Accessory Bar
154WBP17" Steel Wheel
155WBQ17" Alloy Wheel, Grey Metallic Matt Finish
156WBR18" Steel Wheel
157WBS18" Alloy Wheel.
158WBTBridgestone all terrain tyre
159WBUBFGoodrich All-Terrain T/A KO2 Tyre
