I agree, it’s not totally off until ABS is off.With respect, I cannot agree.
Turn off ESC and you still have TC.
Yo can you share what faux carbon fiber cover you used, to cover the piano black in the picture?I’m not sure I follow. The center diff is a manual cable actuated shift over to High or Low/locked unlocked. I don’t think cycling the engine will change anything.
Are you saying you shifted over using the transfer case lever (ball shifter) and when you shifted by back to, presumably unlocked/High, it didn’t work?
If it shifted back, the blinking Telltail light you’re probably seeing will eventually disappear, but the important part is that it engaged. If the shifter is in the high/unlocked position (top left corner), you should be go to go. If you got a bunch of grinding sound then you’re not and should try again
It also might be worth mentioning that the transfer case works in a box pattern. According to the brief I got at delivery, you shouldn’t shift diagonally, ie from unlocked/high to locked/low or unlocked low/locked high.
Haha, that was a pic I found on the internet. I just added the green/red lines. FWIW, I believe there are many choices on Amazon.Yo can you share what faux carbon fiber cover you used, to cover the piano black in the picture?
