Bell Auto Services (BAS) CTEK D250SE charger bracket
Thanks!
But take your time, no need to hurry. I'm currently load with work.
Dead easy from scrap of aluminium thanks to everyone....
I’ve had a very wet day today, can’t get on with much else so cut out a mounting plate for myself incase I decide to get a Ctek D250SE for myself. A piece of sheet galvanised steel tidied up with some zinc spray.
Yes, zinc spray is it. (y)
I use it all the time.
No progress today, awaiting parts, but this is the plate plumbed in and firing on all cylinders in Pete's vehicle:
I am about to install my D250SE in a week. Can i ask what guage the negative wire is from the D250SE and did you connect it to the Aux battery negative post or the chassis? Also, did you utilise the smart alternator red wire to an ignition source?
I used 16mm² cable with an M8 ring connector at each end. Length in photo is 250mm (measured to cable ends) - you could go a lot shorter. It's connected to the M8 stud on the negative terminal of the auxiliary battery.
The CTEK manual states a minimum cable size of 4mm²/AWG12.
Final connections - earth lead to auxiliary battery is far too long - ideally it should be 165mm measured tip to tip with M8 ring connectors:
And temperature sensor taped to the the auxiliary battery near to the positive terminal. (I might investigate the thermal paste mentioned in another post):
I'm going to leave the smart alternator cable unattached for the time being, taking the lead from what Ineos have done with the Smartpass, at least until they come back with answers to the outstanding questions on this topic. I am minded to attach them if I get no sense.
Curious, did you connect the Smart alternator cable on the D250? What of the 120 smart alternator cable?
I'm going to leave the smart alternator cables unattached for the time being, taking the lead from what Ineos have done with the Smartpass, at least until they come back with answers to the outstanding questions on this topic. I am minded to attach them if I get no sense.
As indicated by others when re-connecting the batteries, I got these warning lights in the tell tale:
Odd that diff locks that won't work without centre diff or low gear will illuminate...
And the lockers up top continued to flash rapidly for a good period after the vehicle was shut down:
With engine running - things seems to be indicating that they are working:
Hi DCPU, I have my D250SE mechanically installed but after some advice regards the black wire from the D250SE. Did you connect it to the negative battery terminal?
No *, I understand this to be the linked to the charge voltage for various battery types; and as standard we have a wet battery, then it is correct to leave it unconnected:
* I've made the assumption that you were not talking about the large black wire, which is the battery temperature sensor, which I've taped adjacent to the positive terminal of the auxiliary battery (photo earlier in thread).
No *, I understand this to be the linked to the charge voltage for various battery types; and as standard we have a wet battery, then it is correct to level it unconnected:
Thank you so much DCPU if you had not replied I would have connected that black wire.
Have you checked your battery type?
Mine's a wet battery, "EFB" in the parlance. Let's not assume your's is the same without checking first.
As with Jean Mercier's post on Smartpass changes, it would not be unforeseeable for Moll to provide a substitute battery type if there were shortages of the standard type; or indeed any other form of normal change process in the manufacturing of a complex vehicle.
Mine is an "EFB" also.
Hi all, did we get anywhere with Ineos regarding why the ‘red’ wire on the ctek 120 is not connected to the smart alternator via +15/ignition?. Ctek kindly sent me the 2 missing busbars connecting the 120 to 250 this week, along with a rather cryptic note saying
The battery charger that is installed in Grenadier does not have the same function as CTEK's SMARTPASS, but CTEK see no problem functionally that Grenadier battery charger is completed with a D250SE“.
Given the fact the 120 red cable does not connect to anything, the comment is understandable. However I have asked Ctek if the wire can be connected and why not if the alternator is a modern smart one (unless Ineos have removed that functionality, but would think it’s tied into the bmw end of things. I am not a sparks, but now have 2 dangly red cables looking for a home and hate loose ends….. :-)
Not yet.
See @Jean Mercier's post with regard to what is now being fitted to vehicles arriving at agents (I'd link the post in but can't seem to locate it!)
Edit: now found:
Post in thread 'CTEK SMARTPASS 120S and 250SE DC to DC charger basic features and install information' https://www.theineosforum.com/threa...-install-information.12412843/post-1333209781
Given the fact the 120 red cable does not connect to anything, the comment is understandable. However I have asked Ctek if the wire can be connected and why not if the alternator is a modern smart one (unless Ineos have removed that functionality, but would think it’s tied into the bmw end of things. I am not a sparks, but now have 2 dangly red cables looking for a home and hate loose ends….. :)
CTEK seem very positive in comments to several owners, myself included, that it's OK to attach the red wires. I'm also trying to recall who posted some comments on the functionality that made a lot of sense... 🤔
