Is anyone considering aftermarket tuning options to pull more power and torque from the B58 power plant?
Is it worth jeopardising your 5 year engine warranty?Is anyone considering aftermarket tuning options to pull more power and torque from the B58 power plant?
There isn’t to much torque to win if you do not want to stress the automatic which only allows 500 NM max torque in the petrols version (I hope the figure is right)Is anyone considering aftermarket tuning options to pull more power and torque from the B58 power plant?
NoIs anyone considering aftermarket tuning options to pull more power and torque from the B58 power plant?
Main reason I am not considering a tune on the B58 is because I have ordered the B57You guys must be fun at parties.
Depending on how things look, I'd consider at least optimizing the fuel maps.
Once more junkard engines are available from supras and bmws, it be fun to do a stupid build. There is something oddly satisfying about rolling burnouts in a 4x4.
Here's an interesting teardown video discussing the potential of the engine. This guy gets over 1000hp on a stock bottom end. Even if you're not considering a tune, it's fun to see all the components parts and how the engine works.
View: https://youtu.be/MckxlP60cnY
Considering, yes. But will probably pull the trigger once warranty ends. Otherwise it’s not worth it. I’m quite sure you haven’t driven the petrol, might be wrong, but it does have quite a nice pull to it. Not sure you’d want to go overboard so quickly.Is anyone considering aftermarket tuning options to pull more power and torque from the B58 power plant?
Thats what I was on about. Just imagine that’s just stage 1!! It goes up to 3 or 4!!There are already multiple threads on this topic on this forum - you can find them by searching either B58 or 8HP51.
The B58 in the Grenadier makes 332 lb. ft. of torque (despite being capable of much higher output). The 8HP51 version of the ZF transmission that is paired with the B58 has a max-torque rating of 369 lb. ft. of torque. That is just 10% higher than the existing engine output. That leaves very little headroom for tuning up the output of the B58, while staying within ZF's specifications. I cannot imagine either Ineos or ZF recognizing a warranty claim for any damage to the power train if a tune crosses that threshold. We are talking about any trouble at all with the engine, transmission, transfer case, drive shafts, joints, axles, exhaust, etc. While it is commonly understood that the 8HP51 is a strong unit, and is probably capable of handling more than 369 lb. ft. of torque, if you flash the ECU, you may be completely on your own with repairs to many of the major systems in the vehicle.
Some Toyota Supra and BMW owners (who also have a B58 and an 8HP51) are chasing more power, and this has led to a market for upgrades to the 8HP51, so that it can safely handle added power. A Stage 1 upgrade to the 8HP51 starts at $6,000 (US), bringing its torque capacity up to 850 lb. ft. (and its horsepower rating up to 1000 HP).
Toyota A90 MKV Supra Stage 1 Transmission — Pure Drivetrain Solutions
ZF8HP51 Transmission. 1000HP 850TQ Rating A90/A91 Supra 2020+www.puredrivetrainsolutions.com
This is the wayI certainly wouldn’t consider a tune to up the power and torque but I would consider one that would up the MPG by 50% whilst maintaining the same power output.![]()
Yeah - I didn't see your post before I posted my comment (my post is actually just a copy & paste from a post I made about 6 months ago in another thread). Coincidentally, we are talking about the same company.Thats what I was on about. Just imagine that’s just stage 1!! It goes up to 3 or 4!!
That's easy.There is something oddly satisfying about rolling burnouts in a 4x4.
