B58 engine oil leak (rear main seal)
hoohoohama
5:32 PM
New York
The check engine light I was told was due to the computer glitch as it has to convert from liters to gallons. The system flash will fix this when it comes at the end of August. The dealer cleaned the oil around the starter and told me to drive it another week so they can pinpoint where it's coming from. It looks to be a rear main seal weep. We'll see. The problem is no parts availability.
Thank you for the updates, IMO, I doubt if it is actually the rear main seal, as in my case, I was told the same thing and waited for weeks for replacement parts, and then was told it wasn’t the rear main seal and it was from some sort of lubricant being melted after engine got hot.
So the theory is that you will only see this oil drop if the engine is hot, hence if you clean the oil drop near the starter after the engine has cooled down and leave your vehicle overnight, you shouldn’t see it next morning. but it may show up again after you drive the vehicle for a while.
ErnieB
3:32 PM
Utah
Thanks for the insight. The dealer cleaned it and told me to drive it for a week. In all honestly, I've been so busy I haven't had the time to crawl under to see if the leak is still there. Dealer called this morning to check on it. I'll look at it some time today.
wet & sandy overland
4:32 PM
Bentonville, AR, USA
Having the same issue I think. Seeing some small oil leaks on what I think is the base of the transfer case. Also seeing the black cap on the front left under the hood having some small overflow. I’ve read that is intentional, but I am concerned about the apparent oil leaks. 1000 miles on the Trialmaster. The AC condensation drain forward of all of this is also dripping a lot making it hard to understand if that is contributing to what I think is an oil leak near the transfer case. Transfer case temp is fine. Closest dealer is 5 hours away. Any suggestions?
4:32 PM
Talked to the dealer service and the black cap under the hood is power steering and that’s designed to self vent. The apparent oil leak near the transfer case may actually be the AC condensation drain which he said is known issue for being excessive in the water drain which may be condensation floating back to the transfer case and collecting oil which is appearing to drip. He advised me to wipe it all down and keep an eye on it. If anyone else has experience with this issue let me know.
255/85
2:32 PM
Western U.S.
Unless you have large puddles on the garage floor I'd follow the service manager's directive. You need to monitor things frequently to discern where the leak is emanating from. Can you tell the difference between different fluids?
5:32 PM
United States
Not a Grenadier owner but just rebuilt the B58 in my BMW 340i and having the same issue.
This just happened to me so I do not have a resolution yet but I believe the previous posts have pointed me in the right direction.
During the rebuild process, I used assembly lubricant to grease the transmission where it mates to the engine (image attached) this lubricant is designed to melt on startup to blend into the engine oil when used internally.
During the first startup of the engine, no leaks were observed from the starter motor until the engine was ran for 15 min. Upon seeing the leak, the oil was removed with a rag and brake cleaner, and the car sat overnight with no leaks present in the morning.
Second startup, no leaks present until 15 min into running and then the leak appears in the same location. Working with the information the previous posts have provided and the reasoning of the dealership, this must be an issue that occurs when the assembly lubricant reaches the temperature it was designed to melt and combine with the engine oil at.
Due to the location of the leak, it does present as a rear main seal issue, so to do my due diligence I will be removing the starter to confirm our working theory.
Thank you all for your contributions and I will post again with an update after I have had time to remove the starter and get a scope camera up near the rear main seal.
IMAGES: leak location, assembly lube front and back, transmission location where lube is applied during engine assembly.
