Axle gear oil…what are you using?
Grenadiertrialgirl
11:13 PM
Washington D.C., DC, USA
About to do a service on my Grenadier and would like some insight from people who’ve done it.
Changing oil and filter this weekend and the plan is to change diff fluid next weekend.
Where we got the Grenadier from they are saying they use Kendall Special Limited Slip 80w90
Looking at Grenadiers spec sheet they are calling for Fuchs Titan Supergear 80w90
For the life of me I can’t find where to buy the Kendall gear oil and when I look up the Fuchs I don’t see anywhere where it says it’s for a limited slip diff.
Reason I’m being so anal about the whole thing is I will save my money ($800 at Grenadier) and do the work myself. I will save all receipts and document all milage and amounts. I am even going to use their specific oil brand recommendations so IF something happens I have a leg to stand on.
So can anyone assist with this? Does the Fuchs have limited slip? Or is there a brand that meets ALL specs and criteria so IF an issue were to arise I would still have a leg to stand on?
Right now I’m leaning towards this….
Thanks so much!!!
Titan Super gear , is nothing special the specification is GL - 5
Every lubricant manufacturer in the USA should have a direct equivalent.
Stick with GL - 5 don’t bother going with anything fancy or higher spec. It a very well proven specification.
Cool this is what was thinking so as long as it meets the GL-5 spec it’s essentially within the manufacturer requirement specs yes?
yep - filled my leaking front differential up this week with TRIPLE QX EP 80W90 GL5
I do not have the receipt with me at work, but my dealer 12k service def did not use Fuchs,
Just got home. Receipt from RDS says Kendall special limited slip 80w-90.
For the transfer case it says Kendall SHP Syngear FE 75w-90
Just ordered my oil from RM European.
Went with the factory fill product:
Fuchs Titan Sintopoid 75W90 for the Transfer Case
Fuchs Titan Super Gear 80W90 for the front and rear differentials
Are you guys changing the transfer case oil?
I changed mine at 2500 miles. In hindsight it probably wasnt necessary. Mine drained clean and clear with zero visible contaminants…
The diffs however definitely needed it with lots of metal shavings and cloudiness in the oil.
https://www.fcpeuro.com/ Has all the fluids you need. I just ordered differential, transfer case oil, coolant, brake fluid and an engine air filter from them. Pretty sure it shipped from their Arizona location.
Doesn't that company give lifetime on oil, you just purchase first time and ship back and they send out new oil? I have a friend who does that with his VW
I used Amsoil 80w90. No real reason. It popped up when I searched for it and it was the right type. Very scientific.
Not sure, I’m have to check that out.
I believe it is true. I've used them all the time but never returned oil. Might have to do that now.
From their website
Yes, our lifetime replacement covers every single part we sell, including wear-and-tear items like brake pads, spark plugs, gaskets, rotors, filters, belts, wiper blades, etc. This covers every part across every brand, including OE, OEM, genuine, performance, aftermarket, and re-manufactured parts.
