I got my Fieldmaster without the Auxiliary Battery and now I regret that.
Is it easy to add that now? What components I need to buy?
There's Good News and Not So Good News: Good News: Adding an auxiliary battery to manage a car fridge/CB radio/ camping lights etc is not a great obstacle and well within the capabilities of a local automotive electrician.
Not so good news: If you are contemplating copying the setup as per vehicles which have the so-called "electrical preparation" including additional start battery as an auxiliary.. then sadly: NO. This option was added in during assembly and has additional heavy duty wiring front and rear, additional busbars, fuses, switches, outlets etc as well as software implications. Furthermore there is as yet no easily obtainable wiring diagram...( waiting....waiting)
The wiring- aux battery option, the "Rough Pack" (f/r locking diffs) and the Safari windows were the three "now or never" major options which had to be specified in advance.
Do you have the switch panel and no aux battery which was always an option or did you do with no aux battery and no aux switch panel?Thank you for the good news.
And yes sadly Ineos customer support confirmed the same bad news.
I bought it without the AUX battery and without the AUX switch panel.Do you have the switch panel and no aux battery which was always an option or did you do with no aux battery and no aux switch panel?
I am in a similar situation,bought intending to fit Lithium as an auxillary.Have the Ctek 120s and 250se and the plate to join them but no original mount for the 120s and ,of course, no securing bracket for the auxillary battery.Local agent does not have a parts diagram so unable to order from Ineos.....any one have either of these items surplus to their requirements?I got my Fieldmaster without the Auxiliary Battery and now I regret that.
Do you have a photo of what is installed under your rear seats? I am no sure what you are missing, as I thought all AU models came with a 120S and hence a mounting bracket (so that must be wrong).I am in a similar situation,bought intending to fit Lithium as an auxillary.Have the Ctek 120s and 250se and the plate to join them but no original mount for the 120s and ,of course, no securing bracket for the auxillary battery.Local agent does not have a parts diagram so unable to order from Ineos.....any one have either of these items surplus to their requirements?
If you're doing the rest of the system, the brackets to secure everything should be an easy solution, the threaded bolts/holes all exist in the chassisI am in a similar situation,bought intending to fit Lithium as an auxillary.Have the Ctek 120s and 250se and the plate to join them but no original mount for the 120s and ,of course, no securing bracket for the auxillary battery.Local agent does not have a parts diagram so unable to order from Ineos.....any one have either of these items surplus to their requirements?
I gotta ask... what's your plan for 400Ah??I have the switch panel, but not the aux battery. Frankly, it didn't make any sense to pay that much for a measly 1kwh of extra power. I plan to put a 5kwh lifepo4 pack in the trunk and run it through the switch panel back to the main bus. Only real wiring I'll need to add is a main battery disconnect because I don't want the pack charging the main battery when I have it on.
Just an aftermarket winch. What on earth needs 5kw of power from my car! Even once I get a ham radio setup figured out, I'll probably only have a 100w HF amp.I gotta ask... what's your plan for 400Ah??
Ehh. The storage is for all my fun projects. The winch just requires the hi power circuit.Now I'm even more confused about why so much storage for winch operation, when you're completely fine with <100Ah of SLA for winching operations
