AUSTRALIA: Third party suppliers for the Grenadier
EVACOOL having a massive sale tomorrow between 7am and Noon. At Sunshine Coast Showroom.
Easter must be close.
Finally, nice to see an Aussie grille light conversion kit from GrenX, using custom Lightforce Venom lights, see item 2.
5.7 amp draw so 10 amp or 25 amp circuit will work. RAW Lumens 7,850, effective lumens 4,407.
My single row 20 inch Lightforce Viper has 4,598 effective lumens, which is a lot of light.
NEW LINK
LED LIGHTBARS, LIGHTS, WIRING HARNESS, ETC.
In Australia popular brands of LED lights include (in no order):
  1. INEOS (LED Lightbar);
  2. GrenX Lightforce Venom driving light grille kit here;
  3. Lightforce (Spot lights, LED Lightbars and work lights);
  4. ARB USA and ARB AU (LED Spot Lights, LED Lightbars);
  5. Ultra Vision (Spot lights, LED Lightbars and work lights);
  6. FYRLYT (Halogen Spot Lights);
  7. Teralume Industries X Strip lights. Stripe lights also available at DRIFTA, PDP and ÓFFROAD Living (White and Red light model);
  8. Expedition HQ Camping lights kit;
  9. Laser Lights Australia (LED Spot lights, LED Lightbars and work lights);
  10. Perception Lighting (Spot lights, LED Lightbars and work lights);
  11. The 20 inch Narva EX2 double row lightbar can be attached to the top hoops of the Roo Bar using the Narva 2 inch tube mounts (Part #72296). Look here;
  12. Great White (LED Lightbars);
  13. STEDI (LED Spot lights, LED Lightbars and work lights); and
  14. WIRING HARNESS: The STEDI™ SMART Harness for the INEOS Grenadier is for those owners who are looking to run auxiliary lighting using the factory switch controlling the grille lights here.
Unrelated to the previous post Lightforce have up to 20% off sale for 3 days only. The LED lightbars were only 10% off.
EHQ FB page is showing a new EGR Rolltrac for the INEOS Grenadier Quartermaster. Not on EHQ or EGR's website as yet.
@Mudnut
A couple more videos here:
Blacksheep Australia is having an up to 20% off sale for Easter. Select items only, but great if you need that item.
REDARC are about to release an new Lithium Adventure battery range (called REDLAB). Some info here. They will be well made, but cost an arm and leg.
Images show 100, 200 and 300 Ah battery sizes.
LINKS ADDED
Rhino Rack cargo cases added. See Item 5.
STORAGE BOXES
  1. TRED Storage boxes here, with demo here;
  2. Expedition 134 Storage boxes, Review here;
  3. Razed Products rooftop storage boxes, Model 1, Model 2 and Model 3;
  4. A full off-road power solution built into an Expedition 134 box here;
  5. Rhino Rack Cargo Cases in 48l and 94l versions;
  6. Pelican Cargo cases;
  7. Pioneer Storage boxes;
  8. Dometic GO Hard Storage 50L, look here (recommended by @globalgregors) - subsequently replaced by a Minutemen 80 case;
  9. BOAB Storage Boxes here;
  10. Wolf Pack Pro by Front Runner;
  11. CAOS cases and boxes;
  12. TOUGHBUILT storage boxes;
  13. TJM Utility cases (4 models);
  14. Roof Rack Mount for Front Runner Wolf Pack; and
  15. The Plastic Man, look here.
SUSPENSION FOR THE GRENADIER
  1. Eibach 35mm Pro Lift Kit, look here (Standard, Heavy Duty and Extra Heavy Duty springs available);
  2. Eibach 35mm Pro lift kit/King Shocks package, look here;
  3. King Shocks Set (4), look here;
  4. GrenX has a full suspension upgrade solution using Eibach springs, custom Bilstein shocks, Bilstein steering damper & rear air bags by Poly Air, look here;
  5. AIRBAG MAN suspension for the INEOS Grenadier here;
  6. Dobinson lift kit under development, look here;
  7. SOLVE Offroad using Fox shocks and Eibach springs. Review here by @Braydo;
  8. LeTech Suspension system lift + 40mm (nearly AUD15,000);
  9. LeTech coil springs +40mm;
  10. Oleo-Pneumatic suspension for the INEOS Grenadier, shipped from France;
  11. JMACX manual adjustment suspension kit here. Also with INEOS ANZ, look here. You will need to contact JMACX by phone or email;
  12. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITH winch;
  13. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITHOUT winch; AND
  14. Some US suspension options being discussed here.
SUSPENSION - GVM UPGRADE AU
  1. Expedition HQ GVM upgrade to 3800kg (Pre and Post Registration, but check), QLD registered cars only. EDIT: NSW GVM upgrade not possible at present;
  2. JRace Industries GVM upgrade to 4,000kg (Pre-registration) including rear axle capacity increase (Townsville Qld). Email: info@jraceindustries.com.au
  3. MORE4X4 GVM upgrade to 4,000kg (Pre-registration) here; and
  4. DMW GVM upgrade to 3,900kg (Post registration) here.
