Audio Upgrade Question
10:52 PM
Portland Orefon
I’m in the process of working with the local dealership in putting together 3 options for audio in each of the 3 versions. My main question is where would you as owners like to see a sub located if you have the second battery under the back seat. We were looking at under the front seats, which not everyone really enjoys, in the back door which I really like from a sound quality and out of the way solution, and attached to the passenger rear quarter panel above the wheel well. Hoping to get some great input. The rear door downside is of course you can’t do the drop down table add on:(. The system is plug and play and all attachments are to existing bolts and or threaded surfaces and no cutting other than the tweeter locations in the pillars will be needed.
It might be worth reviewing the posts from @Dave Rosenthal in this thread before committing to the back door. Dave was analysing a drone and resonance in the back door and glass. He's been quiet on the forum since early December so I'm not sure where he got to for possible solutions.
isn’t there a way to upgrade the sound quality “a bit”, without putting a massive base in there?
I mean it doesn’t have to be “all or nothing”. Usually there’s a golden path in between.
For me. Cargo space/cargo flexibility is high up on the priority list.
Some might be gunning for perfect sound, but I would guess the majority would be happy with (as we say in Sweden) “Lagom”, meaning roughly “just the right amount”?
Maybe I’m out of touch….
PS. Also for me. The mic is a bigger issue than the sound.
It's big that's for sure 😲
In Arizona @IG_in_AZ can crank up that sub and at most he would annoy his neighbours. In Sweden @marcusnilsson you would annoy eight neighbouring countries and have Blue Whales beaching in the Baltic 🔊
Exactly what I was thinking - although Wisconsin and Minnesota are basically Scandinavia West, and the WORST nightmare is annoying your neighbor. Imagine the pursed lips and disapproving looks at the church Friday night fish fry. Makes my skin crawl even thinking about it. Really value the cargo space, and love the Bison Gear cages above the wheel wells - would hate to sacrifice that. Also kinda doubt that “heavy base” features prominently in the musical preferences of most Grenadier owners.
Hidden 10" subwoofer I have listened to a base track on this install and it is impressive
I have this sub in my trunk. Its sealed and with the element downfiring.
Its 21" x 14" x6". I have an extra long cable so I can move it around or remove it if I put luggage in the trunk. Sounds super clean.
Sound In Motion of Watertown MA did a great job installing a 10" subwoofer in the passenger footwell such that it is quite well hidden yet performs great.
I suspect people's tolerance for this varies quite a bit. No complaints so far but perhaps that is because when the bass is loud enough to be annoying, the whole car is vibrating 😁.
Hey Parb, can you show a couple pictures of this in the truck? Did you run it through an separate amp?
