Americas Audio Upgrade in San Diego Area
Duff
5:55 AM
California
The title says it. Does anyone have an audio shop in the San Diego area that's competent in upgrading the stereo in a Grenadier? I can live with all the quirks except the less premium audio. Thanks in advance.
Sub
Link to the speakers:
Front Audio Frog GS10, GS60, Rear GS42
Amp with DSP Fully active setup -
Sub Amp with DSP processing. https://audison.com/product/af-m1-7-bit/
6 channel amp for door and tweeter. https://audison.com/product/af-m6d/
I have the sub in a box in the trunk. Longer wires so I can put it in top of drawers if I add them.
Tweeters in the A pillars.
Full sound deadening in the doors and on the floor of the trunk (under the carpet).
Calibrated microphone and computer for tuning the dsp. Retuned after 30hrs burn in and increased the power levels by 3db. Mounted the sub controller knob to the right of the steering wheel just below the trim line.
A special bracket was designed to mount the amps under the passenger seat, I wanted to keep my rear seat open for a second battery.
Sub
Thanks so much. I haven’t needed to put aftermarket audio in a vehicle in a long time. This is really helpful. I’m sure it’s going to be a fun project.
Some pics, sound deadener installation
Speaker installed
Let me take some pics of the a pillar in a bit when the sun comes out.
Also,
There is an airbag sensor in the doors.
Pay attention to the how you power down the vehicle and get the computer to go into deep sleep. Get the car into deep sleep and disconnect the battery before you get into the door.
If you don't, and you disconnect and reconnect the side crash sensor you need to do a trip to your dealer to have them reset the airbag error message. I had to do that, to 3 minutes at the dealer (they did it for free).
Give Reus audio a call in Orange. They did mine and made all the templates for varying spec systems. I got the mid range option and it’s epic.
Thank you!
Also,
good to know, like I said it’s been a while since I’ve had an aftermarket system installed. There are probably a lot of considerations I’m not even aware of.
