Appreciate some help with adding an AUX battery
parb
10:54 AM
Silicon Valley, CA, USA
Hey, I'm going to be I'm Miami over Christmas. If your truck drawers are built by then mind if get to take a look at them?
chrsbe
7:54 PM
Sternwartestraße, Wien, Österreich
I have been taking the kids camping pretty often and the power station we had wasn’t really cutting it. I decided to upgrade to an EcoFlow Delta 2 which has 1024WH and can run at 1,800W output. I also added the EcoFlow alternator charger which is great because it outputs 800W and charges the Delta 2 in a little over an hour. I thought about going with a regular Lifepo4 battery and a dc to dc charger and then an inverter but I couldn’t find anything that would charge a battery as fast as the alternator charger which only works with EcoFlow power stations. I am not saying that a faster charger doesn’t exist, I just didn’t find one. If something does exist I would love to know.
I got the Delta 2 to fit under the rear passenger side seats by removing the JBL amp which I never used anyway. I would like to expand the capacity of the delta 2 using a lifepo4 battery but everything I am finding online talks about taking a battery and having it charge the power station using xt60i cables. That’s fine, but how do I get the battery charged? I have watched so many YouTube videos and they all say expand capacity, yes you are expanding capacity but how do you get the battery charged in order to expand the capacity of the power station? I am really new at this electrical stuff and I know that many on here are very experienced and knowledgeable. I had an idea and would like to know if it would work and if these are the correct parts to use.
Use an AC to DC charger and plug it in to a 110v output plug on the power station and then to the life Po4 battery.
Use a DC to AC inverter from the life Po4 battery to power things like a fridge etc …
Now the alternator charger is charging the power station to 100% in about 80 minutes. That power station charges another battery (not sure on speed though). I use the power station for some things and the extra battery for other things.
Would this setup work? How do I know how much input the life Po4 battery can handle? I would use the highest rated charger as long as I am not overdoing it.
The reason I chose a DC to AC inverter off the battery is because I don’t see any DC to DC inverters. I need to something that connects to the battery for output and then carries the power to plugs.
Am I losing or wasting any power by going from 110v from the power station then converting it to DC so it charges the battery and then converting it back to AC for the output?
Below are the items I was looking at.
12V 100Ah LiFePO4 Battery Group 31 Lithium Battery With Built-in 100A BMS, 1.28kWh Up to 15000 Deep Cycles Rechargeable Battery for RV, Marine, Solar System, Van, Trailer, Backup​
LiTime 14.6V 40A Lithium Battery Charger Mountable for 12V LiFePO4 Lithium Battery with LED Indicator and ON/Off Switch, AC-DC Smart Charger for 12.8V LiFePO4 Lithium Batteries, 40A Fast Charging​
500W Power Inverter, Car/Light Truck 12V DC to 110V AC Converter Dual 2.4A USB Ports Car Charger Inverter with Cigarette Lighter Ports for Smartphones Laptops Tablets​
Thanks,
Adam
View attachment 7877854View attachment 7877855
Great to heat that a delta 2 could be fitted under the seat. Adam, would you mind sharing pictures of your install?
1:54 PM
Miami Beach, FL, USA
There’s some plastic cutting involved. You need to remove the auxiliary battery mount. Even though my car didn’t come with the dual battery the mount was still under there. You also need to remove the subwoofer (which I really never cared for anyway). Then you have to cut the plastic trim under the seat cushion.
Chook
6:54 PM
Brisbane QLD, Australia
Thanks for sharing :-) I'm also looking for best place to store my Delta2. My first thoughts were to put it on top of the transmission tunnel between the seats but the Delta2 is slightly too wide to fit there also without cutting. I just won a Delta Mini in the Boxing Day Sale competition which looks a little smaller so it might fit :-)
1:54 PM
I am going with a Delta 3. I have a drawer system being built and the Delta 3 will sit behind the drawer system and the back seats. I used the space under the seats for a bunch of recovery crap for now.
chrsbe
7:54 PM
Did you check of it is safe to operate it lying down flat?
Chook
6:54 PM
Ok you will realize if this causes thermal issues. If the fans can't get rid of the heat ecoflow will shut itself down i guess. No big risk i would say.
I was going to put my Delta2 on the transmission hump between the rear seats so the rear vents from the aircon would feed directly into the Ecoflow fans (remembering one side sucks and the otherside blows so make sure facing the right way round)
Chook
6:54 PM
Ecoflow Delta Mini fits between the seats and gets airflow from the car vents
