Aerial
beg
9:35 PM
Scotland
Has anyone located the dab aerial?
I thought it was under a small panel in the centre of the roof immediately above the windscreen! Unless another owner out there has any clue.
Reactions: beg
Once we have had the infamous software update and the reception is not any better then will need investigated with a look to upgrade .
I think someone found a DAB amplifier somewhere in the rear behind the trim panels.
Hi beg, both @rovie and @Jean Mercier located the dab amplifier, which was located under rear panels. See link below. DaBulll
Never mind. the aerial why can't you turn the damm radio off it always seems to. be on.
@DaBull Thank you for forwarding it. I wasn't that fast yet!
How do you highlight someone's name in blue ?
@DCPU I can't tell if you are 1) trying to reverse engineer the vehicle, 2) take enough of it apart and back together again that you can say you built it yourself, or 3) you are just that damned curious.
I respect and salute you.
We should all chip in and buy him a Lego set so he stops breaking down his Grenadier.....
To be clear ~ I did not do this. The hard work was done by someone else. 👍
