Adding a third battery.
4:50 AM
Pittsburgh
I think I'm going to add a third battery and put it in the drawer system to handle "camping" loads.
I know nothing about automotive/rv battery systems, so before I spend 3 days down the rabbit hole, do any of the wiring GuRu's have a recommendation on say... removing the existing dc/dc and adding one that can handle an additional renogy 300ah lipo, orrrr, should I just add a second dc/dc off of the second battery? No real plans to add solar, but if its there it's there.
Any thoughts appreciated.
I use something like this with a DC/DC charger built into the box. 100Ah Lithium battery.
I have left the existing dual battery system well alone to avoid any potential warranty issues. After the warranty expires, I will change the system to a more traditional dual battery system.
I use a triple Anderson plug to power the DC/DC charger and all the ancillaries are run off a 12 gang fuse box which is connected to a single Anderson plug. The whole system is easily disconnected and can be used in other vehicles.
I have the same concerns. So you’re just running the system in parallel. Where is your positive tap point to feed this second system? I have a tembo tusk drawer system that was given to me years ago, and it’ll fit the short Gren load area, and I noticed it actually has an area behind the drawer for the battery, so I’m just going to jam all the electronics in there.
Thanks.
Thanks.
There is a 40amp fused cable outlet in the battery compartment under the rear seats. The cable is a similar setup to those in the footwell: sealed ends and taped to a loom. The three wires are 12v "live", 12v ignition switched and an earth. The outlet is suggested by Ineos for use as an air compressor connection ...
I'm in the process of using it to charge my "diy" battery box, using the ignition activated 12v wire as the signal source for the smart alternator -dc charger setup.
The battery box chassis is a metal 'first aid' cabinet from the local hardware store.
The 12v outlets comprise 2 'merit' sockets, a standard 12v cig. socket with 5v 2.1A USB plug-in adapter and 2 Anderson plugs (grey). The red Anderson is for alternator input to dc charger, the yellow Anderson for solar input. Blue Anderson on top at the rear connects to the 100AH LiFeP04 battery.
Apart from the Victron smart meter, there's also a Bluetooth 500A smart shunt inside the box.
I'm contemplating how I might repackage the whole lot, including the battery in a suitably sized "Pelican"-style case....View attachment 788352620250106_115520.jpg20250106_115550.jpg20250106_120435.jpg
I also use a Battery Box if needed. I have not used it in the field yet, but it was in the car yesterday being tested.
View: https://youtu.be/6NCvx92AgVI
Some models and reviews of Battery Boxes here.
I had considered one of those, but, I have otherwise inaccessible space the size of a battery in the drawer system I've decided not to toss out for now. Life was easier with 3 group 27 lead acids and an automatic battery system. Now I've got a mishmash of sizes, chemistry, and a smart alternator, which I would toss for a 250a GM 1 wire any day.
I have a question for ya TheDocAUS, I haven't dug into the wiring yet, but I take it the ctek merely permits OEM battery 2 to trickle charge battery one when it detects the need? In some ways it seems this system is the worst of all possible setups. I always used a system where I could flip a switch and combine them for a jump, or when when winching If I thought best. Any thoughts as to why I couldn't just put a 500a contactor separating 2/0 between them in parallel to the ctek, and functionally bypass the ctek when I see the need? In fact... If battery one and two are the same, why couldnt I just eliminate the ctek and put an automatic dual battery controller between them like a traditional setup? Does the "smart alternator" hav some sort of issue if the batteries are directly connected?
That's a pretty neat set-up @DenisM. I'm contemplating a simpler version using just a Redarc Alpha DC-DC charger, If/when I go the third battery in a box route.
One question, what is the type of socket/plug you used for the smart alternator signal wire?
Cheers
Steve
The Ctek does a bit more than just trickle charge the starter battery from the Auxiliary @Zimm . It will also connect to jump start if needed. The following extract from my manual gives a fuller description
The Smartpass operates as follows. This is summarised and modified from the Smartpass user manual (Ctek 2019) to reflect the Ineos installation.
  • Charging auxiliary (service) battery from the alternator (constant charging voltage):
    • The SMARTPASS 120S charges the auxiliary (service) battery at up to 120A from the start battery when the alternator is running.
    • This function is switched off when the engine is not running.
  • Start assistance:
    • SMARTPASS 120S automatically connects the auxiliary (service) battery to the starter battery for 10 sec to assist if the starter battery on its own is unable to start the engine.
    • After the start assistance function has been activated, SMARTPASS 120S will display a fault indication until starting has been achieved without using the start assistance function.
  • Separation of the starter battery and the auxiliary (service) battery:
    • SMARTPASS 120S separates the starter battery from the auxiliary (service) battery when the engine is not running.
  • Dynamic overcurrent protection:
    • SMARTPASS 120S has overcurrent protection to shield the product. Overcurrent protection permits up to 350A to be sent from the alternator temporarily so that charging will be accelerated.
  • Battery temperature protection:
    • SMARTPASS 120S protects the battery by switching off charging if the auxiliary (service) battery temperature rises too high.
  • Starter battery trickle charging:
    • The auxiliary (service) battery trickle charges the starter battery to compensate for the self-discharge of the starter battery.
    • The auxiliary (service) battery charges in periodic 3-second pulses when its voltage is higher that of the starter battery and the voltage of the starter battery is low.
    • Note: I have had ongoing conversations with Ineos Support and their understanding from Ctek engineers is that the Smartpass will terminate this function when the Auxiliary battery charge drops to 50%. They have also advised that they plan to undertake testing to confirm that this is the case. This information is therefore provisional pending Ineos’s final advice.
  • Auxiliary Battery Charging.
    • The SMARTPASS will start or stop charging the auxiliary (service) battery when the following voltages are seen by the unit. Note INEOS do NOT connect the red smart alternator wire.
    • Cut In: >13.1v for 5 seconds (engine running, alternator charging).
    • Cut Out: <12.8v for 10seconds. (engine running, alternator not charging).
Cheers
Steve
Hey Zimm - I routinely deal with additional batteries in my snow plow vehicles and it doesn’t take much. As long as you’re stacking batteries in PARALLEL (meaning you are doubling the amperage - not the voltage), you will be OK without additional modifications to the electrical system. Your alternator will charge both batteries, albeit at half the rate. I do it because I run heat/defrost, lights, radio, plow hydraulics, wipers… (not in the Grenadier) and that second battery is a life saver!
Just don’t hook up an additional battery in SERIES… this will double your voltage causing damage. A quick check online showing the meaning of parallel v. series terminal connections is easy to find. Finding a spot to “hide” a second (or third) battery on a grenadier will be the trick. -Mark
Thanks. I have the series parallel down. ;) what I don’t know is what the “smart alt” is doing, and what the creek is doing, and what they looking at, so I don’t know how one or the other going to react (or what warning lights will go off) if I suddenly toss a battery in parallel to lessen the load on the primary battery while winching.
My plan was for a dual motor gigglepin winch, and a third battery for house loads. Simple and robust battery combining is what I need. The portable boxes are nice but a waste of space for my situation, so I’m trying to avoid that.
Since the two batteries supplied are alike, maybe I’ll rewire them with an old school separator, and utilized the ctek for the additional lithium battery. The old style just monitors voltage difference and combines them within the parameters preset. I don’t know if they will play nice with a smart alternator if it’s varying voltage output, which is what they do compared to a constant voltage alternator, right?
I use a Kings BatBlock25 which offers a prebuilt version of some of the solutions/brands above, running it from the Ineos second battery (mainly because it was easier to connect to and didn't require disconnection of battery from car, and using the ignition active wire from the 40A spare 'compressor' lead. I did think about using that for the power too but in the end decided to pull the load as directly from the battery as was possible.
I also took the BatBlock 25 to pieces to check its build quality and noted the two 50A Anderson sockets for in/out share a single 50A fuse and wiring, and the 3 12 volt sockets share a single 15A fuse. Not of concern for my use case but I definitely recommend understanding the internals and also knowing which fuses to keep on hand for spares.
And lastly I swapped out two of the 12 volt sockets for 100w USB C PD (20V) so I can charge laptops, phones, and run Starlink mini.
A must do in my book. A quick way to identify when shortcuts are taken.
Thanks for this hint, I wonder where I should wire my compressor which is located at the place of the not existing 2nd battery…
First I want to connect it to 5 stud bus bar, but cannot find the littlefuse material for the spare output port in the net….
Can you give me a description or a picture were the compressor cable end is located exactly?
Found it. Has only a 40 A Fuse, so I take the Littlefuse free port with 300 A and changed the too big M8 bolt to a M6 screw:
From the original INEOS compresso outlet under the rignt rear seat I used only the ingition "+" for the ARB switch (also for the illumination). I used the ARB wiring loom and took the yellow cable from the unused diff lock plug1 for the ignition "+" and connected it to the RED-YEL and BLU-WHT cable at the other end.
  • Start assistance:
Cheers
Steve
This is the best description of how the dual batteries are set up I’ve seen so far. Useful info. While the Ineos approach is different to the usual Australian approach to adding a dual battery. I’m not sure it is 100% wrong and maybe I just need to understand it better to work to its limitations.
I’m trying to decide between adding a 3rd battery (lithium) is per usual dual system or upgrade the Ineos service battery with a higher Ah lithium battery and dc-dc charger (apparently that is required because of charging profile differences) to allow running a fridge and lights, as well as service the ongoing drain from opening doors etc for a minimum 3 days, in case solar doesn’t keep up.
I’d be interested in hearing from anyone that has done that. i.e. Does it affect the ability to assist cranking in case of a flat primary battery? Are there any other issues that arise?
Adding a 3rd battery has a space impact, when there is already space allocated to dual batteries, if I can get this system to work for my needs I get to use that space for other things.
I have the INEOS dual battery system, I also added the CTEK250SE and a rooftop solar panel. As long as you have sun around both batteries are kept topped up.
The easiest and quickest way to add a third battery is a Battery Box with a DC to DC charger, which I have done. The Lithium Battery Box is wired from the aux battery, but I still need to wire up the ignition source. I used a KickAss Heavy Duty Wiring kit to connect the Battery Box to the aux battery. It all works, but I will do a final test after connecting the ignition source. Once done the Battery Box only charges when the ignition is on and the car running, otherwise it disconnects from the other batteries. Fridge will be plugged into the BB.
Other parts of my build here.
As part of the Battery Box install I wrote up a Table on the wire ends, I am using the ignition source under the rear seats (my 2 seater has a battery box). I will use a terminal blade splitter on the ignition source wire, so I can use it for other purposes if needed.
1737442509841-png.7884962
I have used the INEOS dual battery system in remote Australia running a fridge and appliances without issues, but I was not parked up for 3 days. I had no issue adjusting across from the traditional setup used in Australia. The CTEK system and the Moll batteries have an amazing ability to recharge even on short trips. It is very good combination, even if different from the usual setups in Australia. I think people who make adverse comments need to look at how the INEOS system works, before bad mouthing it. At least understand it before condemning it.
The aux battery in the INEOS setup does assist cranking if the main battery is flat or low on power.
In my setup the INEOS dual battery works well (esp with the solar panel), but I can plug in a third battery when I need the extra power (120 Ah Lithium). I had a battery box so I might as well use it. The Lithium battery in the BB allows me to use higher powered appliances if needed like a single induction cooktop.
For me I wanted power and flexibility, so in my setup:
  1. the solar panel tops up both batteries, when the sun is out (the Battery Box will only charge if the ignition is on);
  2. the solar panel supplies enough power for the fridge during the day, plus it charges the dual batteries;
  3. the second solar input (Red Anderson plug) with the rear Grey Anderson allows me to plug in my solar blanket for more solar charge (the CTEK250SE has max 20 amps solar input from memory);
  4. I can easily plug and unplug the battery box;
  5. if there is an issue with the BB, I just plug the fridge into the INEOS dual battery system.
I have to agree with you @TheDocAUS its a good dual battery system, just works differently to what Australians are used to. Once you understand and adapt accordingly all is fine. It took a lot of digging to find out how it works though as Ineos in their usual form explained nothing of consequence in the owners manual's. Next edition of the manual will have additional details on decoding the smartpass LED meanings.
Pity the DS250SE has such a low solar panel VOC though other wise I would have fitted one as well. Currently I use a small Victron controller, but will upgrade to a Redarc Alpha DCDC Solar when i get my third battery system completed, which is progressing nicely. Wired up the anderson plug input to the car the other weekend (Look Here) and finished assembling the charger controller box last night. Just need to get my 150amphr Lithium battery (on back order) and then I'll start testing. I'm planning to use a piggy back fuse on the Ext1 fuse to get an ignition signal, The Redarc only needs 2 amps max for this.
Cheers
Steve
Thanks for your comments @TheDocAUS.
Interesting that you have found the onboard power sufficient. What's the watts output of your solar panel? and what's the amp draw of your fridge?
I have noticed significant depletion of the battery just by opening and closing doors without running the fridge or any other load drawing consumers from the onboard batteries. I have a 200W solar blanket that I have fed directly to the Crank battery (because that is where all the loads are coming from), via a 20A Victron MPPT controller. This set-up seems to work ok but not sure what is happening to the second battery. I probably should have got the CTEK250SE instead for solar input as I presume that would balance both batteries from solar?
I have seen the system show a charge rate of 189A when the battery is under 50% SoC (and have a photo to prove it) after sitting camped for 3 days, it still started no problem, but I will never do that again. I presume that charge rate is just to the primary battery, regardless, it is a healthy rate so I wonder what advantage the 250SE DC-DC provides over the current system other than solar input? Obviously a lithium service battery would not be able to be charged at that higher rate so a DC-DC would be needed in that case.
I like the idea of using the already onboard system, but I've been concerned (which is probably also why many are sceptical) about killing both batteries, particularly with potentially deep discharging/charging often. I carry a lithium jump starter, but relying on that often seems also dangerous. Hence my thought to upgrade the service battery to a larger Ah lithium to expand total Ah capacity already onboard so I don't need to be checking the SoC so often . However, not sure what the implications will be to the system's function. i.e. Would a lithium still assist cranking if needed? and will the trickle charge of crank battery still work?
Just for context... I have been using a similar, but smaller arrangement to yours, I use a pair of 40Ah Companion power stations in rotation to run the fridge, which has worked to this point... but it is close to the wire. One 40Ah will run my current fridge for about 24hours but if I upgrade to a bigger fridge (which I need to do for longer trips) and add Starlink, plus any other tech consumers that my daughter insists on bringing 😬, I'm going to struggle particularly if solar input dips, so I need to increase capacity. I've looked at battery boxes but they are BIG! and space is of a premium on longer trips (I travel with swag/RTT only). I had identified an area beside the fridge to attempt building my own battery compartment, but wondered if there is a way to better utilise the Ineos system and not have to add a large 3rd battery.
Appreciate others thoughts, particularly if anyone has (and I'm sure people have) changed over to a lithium service battery.
