Windshield Smear’ers
4:58 AM
Pittsburgh
Yea, this morning at 5am was my first foray in the dark with freezing road spray. The wiper blades were definitely low bid.
Here what I replaced them with, OEM blades are not always the great on any car I owned for winter.
I agree, they aren’t the best. Skip like mad in light rain.
I tried a nice (expensive) set from the local parts store and they were marginally better. Tried the set of Michelin from Costco and they were much better. Now I have 3 sets of front wipers, lol. Living in western Washington I need good wipers though. It rains like 200 days a year.
The Michelin Hybrid are very good. I’ve tried them. But the best is Denso Hybrid which looks marginally better.
I mentioned this in another thread, but will post here again in case it helps you or anyone else. Summary is that after trying rain-x, bosch and stock blades - dense were the only ones that have not skipped a single time for me. Less skipping = less ice build up in heavy storms.
I didn’t have any skipping, it just seems like weak pressure on the windscreen that shows as a lack of squeegee effect. Maybe that’s the same cause as the skipping.
Basically the old school wipers have a metal blade ensuring even pressure along the whole blade on curved windscreen and also they are slightly taller to allow a good contact angle. Hybrids are basically old school blades wrapped up in an aerodynamic shell to make it look modern.
Thank you for pointing me at the Denso. My factory wiper blade on the driver’s side smeared in the overlap area of the two wiping areas. I replaced it with the Denso Hybrid DU-040L (left-hand driven car). The wiper blade does its job very well in winter conditions (snow, rain, salt; snow/ice in the morning on the windshield) at all speeds and temperatures. No need to change the blade on the passenger side. At seven Euros per piece very reasonably priced. I found different lenghts in paper specs, apparently due to inch/mm conversion but blade lengths are indeed identical. Design-wise, the Denso looks indeed better but I do not think anybody would notice that I currently have different models installed. The picture shows Denso top, factory bottom.
