Pretty sure this was covered in depth on here and it is a standard size, stud pattern and offset.Is the rim original Grenadier or a match to other brands, f.e. Mercedes G or Jeep?
Go to a tyre shop and ask them.From what I have been able to research the Mercedes Sprinter Van has the same wheel. But that seems to be it. The LDV T60 has the same stud pattern and PCD but a smaller centre bore (74mm) so those wheels wouldn't fit.
This was posted earlierBonjour
Existe-t-il un schéma du positionnement et des perçages des jantes à 6 trous ?
Quelles sont les jantes acier finalement compatibles ?
Merci de votre retour
Bonne journée
Opted for 17" steel but recently been going back to my first option of 17" alloy. I can see another £200.00 being spent on additions before finally signing the order.I would have preferred 16" but have gone for the 17" alloys as next best option
The steel wheels look ok but I think they are a bit fake/try hard for me
I really don't like the look of the 18" alloys they have chosen but wouldn't have gone 18" anyway
View attachment 7795210View attachment 7795211View attachment 7795212
The 130 x 6 PCD and 84mm through bore matches the spec for current Mercedes Sprinter and the old MK.I VW Crafter vans, but both these vehicles have a 62 offset as standard.
Looking into this right now... but have to ask, why not for the Sprinter Van ?It would be really useful to find out which USA vehicle Black Rhino introduced the 130 x 6 x 52 offset option to suit, as it's almost certainly not a MB Sprinter van! My guess based on the style of the rims they offer with this PCD/offset is that it'll be some kind of 4x4 or pick-up. If we could reverse engineer the Black Rhino 130 x 6 x 52 option back to the appropriate USA vehicle, then it'll probably be a more common vehicle on which we could base a wider search for other suitable after market alloy wheels.
Quelle est la dimension des pneus pour les jantes 17 pouces ?
265X70 R 17 ?
Like DaveB I am now trying to change to the 17 alloys...at first I liked the steel for that more rugged style but then the more I saw the alloys I was swayed...Ineos have picked these wheels forI would have preferred 16" but have gone for the 17" alloys as next best option
