- Local time
- 12:33 PM
- Joined
- Mar 9, 2022
- Messages
- 524
Stock BFG KO2s. Right now I’m sitting at 48lbs front and 50lbs rear. That seems pretty high. My ‘17 Discovery is usually around 36-38psi all around. Also curious if I could get away with running the Micky Thompson Baha Boss 280r70s STD load. They’re 48lbs vs the E-Rated at 64 lbs but the max load is 2756lbs@44psi vs 3195lbs@80psi. Given the weight of the vehicle is 6k lbs wouldn’t be be STD load at the lower PSI be acceptable? Guess I don’t know enough about tires to know why I’m at 50psi in a stock setup with just me in it.
