Thanks, what size P clip?Nice job. I did something very similar but a little more direct with regards to the attachment point using a straight, flat piece of 15mmx2mm aluminium.
Correct if you wish to sleep inside. Although I can also climb thru the cargo barrier in my 2 seater (I cut a hole).But why???
I have never once thought I wish there was a handle inside so I can close the rear doors from inside???
Maybe if you sleep inside I guess??
16mm.Thanks, what size P clip?
Yep. Or just hang out in the load space and eat lunch.But why???
It’s the hole that I’m concerned about. No rivet or stitching to keep it from expanding and pulling off the screw.They are paracord and are fairly robust.
It seems sturdy but only time will tell.It’s the hole that I’m concerned about. No rivet or stitching to keep it from expanding and pulling off the screw.
Tks for that, I was just browsing Amazon for some p clips sizes and saved me a trip under the hood, well until later anyhow.16mm.
Which product is your diesel heater? Thanks for sharing.Had a fun time camping near Blue Lake, Utah
The Diesel Heater is a Must Have !!!!
View attachment 7888100View attachment 7888101
I don't know that Owl has a UK distributorNothing better than getting stuck in, and doing a great jobOwl flat earth rack looks neat and versatile, is their any companies that stock them in the uk?
Generic plastic handle from Bunnings. Did require one spacer to to plumb it up.I used a length of belt leather and also attached pieces above the rear windows as a grab handle.
It fits in well with the great saddle leather trim I optioned.
16mm fits bestThanks, what size P clip?
A great landscape. I would love to accompany you now.Went for a walk with the hounds in Sussex vineyard land. Ended up having to winch a VW camper out who was stuck in the mud. Couldn't tow him as no room to do so, surrounded by parked cars, he'd parked nose in so driven wheels were in the gunk. Had to position the Gren athwart the track on the otherside of the track so could get a good pull thru the post and rail. Think he'd been paragliding up on the Downs. No photos of the winching but here's some afters. You can see on his right front tyre marks, one being his entry and the other to the right a bit 'his' exit and where for some reason he put his brake on - no problem for the Gren!!
Nice walk after that.
Oh and topped the oil up 500 from the change the day before. All is well.
The type species, Australotitan cooperensis, was named and described by Scott A. Hocknull, Melville Wilkinson, Rochelle A. Lawrence, Vladislav Konstantinov, Stuart Mackenzie and Robyn Mackenzie in 2021. The generic name, Australotitan, combines the Latin word "australis", meaning "southern"—as it was found in Australia (which is sometimes referred to as "The Great Southern Land")—with the Greek word "Tιτάν" meaning "titan", in reference to the Greek mythological Titans and the dinosaur's gigantic size. The specific name, cooperensis, refers to the Cooper Creek system near the initial location of the holotype, and the nickname given to the holotype when it was discovered.
