Today Maria and I went to the National Outdoor Expo at the NEC, with free tickets from Ineos Automotive. Still an expensive place to go as we bought a posh waterproof coat for Maria and some collapsible stools.
I'm not sure that Ineos marketing has really worked out what to do with Grenadier owners, the invitation talked about having a test drive and a good look around the Station wagon and the Quartermaster. Anyway, some pictures:
View attachment 7849485View attachment 7849486
Latitude, the roof tent people had a stand with a Grenadier fitted with a MaxTraxx kitchen insert; lovely but pricey.
View attachment 7849490View attachment 7849491
Always LOVE seeing another Queen's Red 😻
Sometimes , when she's tired after a hike or the Gren is tilted away , Her Indoors finds it a little tough to embark.
So a couple of days ago I made her a little stirrup from stuff lying around. Plus a couple of quality exhaust U clamps from a tractor place. The copper nuts provide extra grip.
Installed it this morning on our island off an island - Bruny - and we went for a hike. Lovely day for it!
Ingredients for the step:
U bolts
5mm Aluminium plate, Just the width I had lying around. Could be 3-4cm wider I guess.
Aluminium moulding so she doesn't bark herself on the adge
Gorilla Grip grip tape - on the step , and on the slider tube.
Etch primer and topcoat. I'll put grip tape on the moulding sometime.
One small step for a man , one small step for womankind!
Hello Tazz - thanks for sharing that. I've been thinking about how to put some kind of step to mine as well...
No worries. It lends itself to easy customisation and removal.
Yesterday and today checked my car for damage after two weeks in Spain and about 4000 km driving, from which quite a lot of motorway (Belgium and France) and an estimated 150 km off road.
Conclusions and experiences of those two weeks:
  • got during an hour or two a "Power Steering Error" on the big screen and a red triangle on the small screen behind the steering wheel, but it disappeared after a picnic pause.
  • some days later I had suddenly a metallic squeaking noise under the car, only while moving, even in car wash mode with motor off. Later it changed to a rattling metallic noise. Did creep under the car but didn't find it, but it disappeared as suddenly as it appeared after some hours, therefore probably something got stuck somewhere, and fell off again. Stone probably or wood, less probable.
  • I also got a tire pressure high warning on the hottest day for my rear tires; next day, after a fresh night the warning was still on, probably because the computer hadn't reset it yet, but it disappeared after some kilometers driving.
  • one of the first nights I left my fridge on, to see if my battery could hold it (I have a NOCO power booster in the car), and this was the result, voltage drop from about 12.8 volt to 11.8 volt, therefore OK for one night, but nothing more:
  • I scratched my "Buzz rock sliders" on some rocks but no other damage, although I don't pretend the sliders had to really support the weight of the car.
  • And while crawling under my car yesterday and today I saw a strange "oil-like" pattern on the left frame of the car, but is NOT oil, it is some kind of wax, probably some excess protection wax that melted while the temperature was higher:
  • The car behaved as expected, and it was the first longer trip for my wife, and she enjoyed the comfort, but getting out of it is still difficult despite the "Buzz" side steps / rock slider.
  • And while she first had some mockery :eek: of my underseat bags, after some days she admitted they were great to use! :ROFLMAO:
View attachment 7852269View attachment 7852270
Thank you, Jean, for sharing - always a pleasure to reading your adventures :-)
In be leave, you are not having any major fluid leak.
About the battery drain from the fridge: Did you use the main battery or the 2nd battery as source?
I assume, your fridge is hooked to the official 12V outlet from the booth.
Thank you, Jean, for sharing - always a pleasure to reading your adventures :)
I used indeed the "official 12V outlet from the boot", therefore draining the main battery!
And, as the main battery gets pulse recharged by the secondary battery, it also got drained!
Like many others, I think this is a weird setup of Ineos!
Was anything else on throughout that night, or was it closed up with just the fridge running? That seems like a lot of amp draw. What’s the make and size?… Have you tested beforehand to see what it draws when running? For comparison, an Engel 45 has a draw of between 2.25-2.5 amps with a 50 -60% average duty cycle.
Hearing that the second battery was pulled down trickle charging the first has me considering ditching the smartpass.
JOOCLA MOUNTED ENSUITE
I test mounted the Joocla Single Mounted Ensuite onto the Rhino Rack Pioneer Platform. The Joocla was mounted using KAON Universal Awning Brackets to suit the Pioneer Platform, two or three brackets can be used.
Here is an image of a Single Mounted Ensuite (image from Joocla website):
Here is the KAON Universal Awning Bracket used to mount the Joocla Single Ensuite:
The spacing between the Joocla bolt mountings was 51mm which the KAON bracket can handle without modification. KAON states the bracket spacing is 33mm to 50mm maximum (but it works with 51mm no problems). The Joocla supplied mounting brackets did not work to my satisfaction. They would have mounted the Joocla, but corrugations would have moved and/or damaged the Joocla brackets over time, because of the manner in which the brackets fitted to the roofrack. Better to install it right the first time. An added bonus is I can remove the KAON brackets easily if I wish to remove the Joocla in under two minutes.
No image of the Ensuite on the Grenadier, as I am waiting for some Nord-Lock washers for the final mounting. I did not have enough washers for all the mounting bolts. I then pretends the Nord Lock washers do not cost as much as they do.
OTHER ENSUITES
Other choices of Ensuite can be seen over here under, the heading: MOUNTED SHOWER, CHANGE ROOM, ENSUITE, ETC.
Yes Jean, it's just bizarre the way it all works without a having a diagram or detailed explanation.
I'm touring with two fridges but mainly use one. With the one fridge I can get by one overnight but reluctant to go further without a drive or solar as I just don't know what's going on with the starter battery.
Sometimes in the morning it's 12.3v sometimes it's 12.05 as below. Guess the curve starts to drop away rapidly once it gets low.
I'm not using a cig lighter socket for the fridge but have it connected via a victron smart battery protect on the AUX battery.
I power the SBP/fridge via an overhead switch when driving. When the vehicle is parked up I need to turn the main power switch of the above head panel on to keep power to the SBP/fridge switch.
By morning the Aux battery is always in a much better state than the start battery. (Ctek assured me the smartpass/250 would not drain the start battery - perhaps not all the way down)
I suspect switching the main overhead switch 'on', in addition to powering my SBP/Fridge switch must power up or put on standby, a number of other unknowns in the vehicle causing an additional drain from the start battery. Perhaps the switches I have on is enough to cause a significant drain but I have not measured anything yet.
I know switching the main power switch on when parked also powers up my rear view mirror that I piggy back off a fuse so at present I'm manually unplugging the mirror until I find a suitable fuse that isn't powered up by the overhead main switch - rooky error. As before, a diagram or detailed explanation would be nice. What a fantastic vehicle though... tough as and always have a smile on my face.
My days of faffing about on my driveway with spring compressors are over so I paid the man (TJM 4x4) to install a set of the heavy duty Airbag Man airbags .
Brilliant just what I’m looking for. Let us know how it looks and handles when loaded please. I’ll look for a U.K. supplier ready for when I get my Grenadier back.
I'd put a set in my luggage as we're in the UK in May ; however we are limiting ourselves to 20kg!
😎. Nice thought
. I’ve emailed 4x4 works and they are contacting the suppliers so all should be good
Installed the eibach heavy duty springs and gvm upgrade.. no need for airbags... just something else to de-inflate.. 😁
