You realise you have destroyed a "feature" of the series 1 Grenadier?
@bakepl @Krabby @Tazzieman
To all who have a saggy petrol cap cover...more defined on the lighter colours...I have been for some time now working on a solution to raise it without having to do too much...finally, it is still a wedge and in the first pic you can see the arrow pointing to a rub mark...second pic shows the little lug that runs along that surface...third a forth show you the wedge created to lift the petrol cap cover up as it moves in...pic five shows the top that has to be slightly rounded off because it binds on the top of its housing...
The wedge is 2mm at the thick end and can go to nothing on the other end...mine is a little under a mm...the yellow wedges I know will work and they are ceramic tiler wedges...I used a smear of Sikaflex to hold mine in place...which is black plastic cut, filed, and sanded to shape...double sided tape worked in one of my early prototypes but the thickness can then vary...with the wedges it will be cheaper and easier to get the right result...the yellow wedge can but cut with Wiss tin snips...hope this works for you![]()
Reply to Max
Report Edit Delete Attachment editor Convert to jpg Rotate
That said , I have a packet of the yellow wedges. I need to get all entrepreneurial!
