warning - self locking grenadier with keys inside
Dave, firstly I was watching the car the whole time, which is why it was safe to leave them, where they wouldn't get wet. Secondly, anyone (from Samaria or anywhere else:) could not lock the car then put the keys inside.
I assume it works the old way.
You open the door, push the outside button in with your thumb
Lock the door using the button on the inside and then close the door and release the outside button.
I can't imagine that Jim himself would emerge from a quick swim in Iceland or Botswana and be happy his car was keeping his keys, phone and radio prisoner where he left them....
I reckon he shops online
If the key isn't a proximity key there is nothing to sense.
When i travel I always take the spare key with me in case the main key is locked in, damaged or lost.
i work on the theory there is very little chance both keys will get locked in the car.
you can of course hide a spare key somewhere on the outside of the vehicle.
A bit of busted rubble, concrete, limb from tree can always get you in too!!!
a mate of mine had a small box screwed to the underside of the vehicle with a spare key in it.
Worse case he would need to borrow or buy a screwdriver.
Conversely my wife uses a key lock box on the outside of the car but i had to show her why she shouldn't fasten it to the drivers door handle.
After all, proximity is proximity
As long as no electrickery gets moist.
I don't think insurance covers the $$$ modern keys.
Since this happened, have you been able to replicate the autolock? How many minutes does it take to lock your doors?
Mine locks itself - unlock the car and then fail to do owt it then locks itself. As did both my Range Rovers and Ford Fiesta. The Citroen always locks itself when you walk away. Never leave keys in such a vehicle is the rule IMO.
Purely as an emergency car entry key only, to retrieve a locked in key, just use a blank cut but not coded, it should open the door and with no electronics in a blank handle isn't an issue if it gets moist. For my spare "hidden" house key it is an a small plastic bag sprayed with WD40 and forgotten about for years. (Mind you when I need it I can't remember where I've hidden it 🔑 )
Interesting. I wonder if its a European standard? From my experience in Fords and LRs on this side of the pond, they do not autolock.
I leave my keys in my Defender regularly and used to with pretty much every vehicle I owned that was garage kept. Between my wife and I that’s around nine different brands/models…interesting.
I don't think L/R this side of the pond auto lock- well mine doesn't cos I often leave the keys inside when it is on my drive and I know I'm going to use it again that day
I don't think L/R this side of the pond auto lock- well mind doesn't cos I often leave the keys inside when it is on my drive and I know I'm going to use it again that day
I wonder what it is? Could it vary by country, model? What’s ironic, and completely opposite of the OPs issue, is that I’ve owned several vehicles that won’t let you lock the door, even if you physically hit the doors lock button, if your keys are in the car.
TBH, I thought when I first read the OP’s post, that maybe he accidentally hit the lock button on the door on his way out and didn’t notice. 🤷🏻‍♂️
My Defender 110 doesn’t autolock either but it is a 1996 build with somewhat questionable door security.
Exactly the same as the Grenadier key and so many other keys
My Mercedes key and my wifes mini key both have physical keys hidden in them that open the doors.
Easy enough to use the one from the spare and hide it on the vehicle.
is a mini key a smaller version of a standard key?
I have left the keys in mine overnight. It didn’t lock. I’ll be more careful now.
Unless there is a hidden setting somewhere?
Or could you have somehow hit the lock button on the door on exit? Seems unlikely but ???
A locksmith may be able to cut just a blade key to take swimming with you or hide outside somewhere
