Warning light symbol
4:55 AM
Austin, TX, USA
What does this warning symbol mean? I looked in the manual and it’s not identified.
It means you either have lane departure turned off, or for some reason the front camera is not picking up what I wants to pick up (perhaps you are in an area that doesn't have speed limit signs and it is angry about that)
I also get that when I’m on back paths that do not have shoulder lines painted.
It’s intermittent and comes on usually just after starting, then goes away after driving. I also get a “speed assist limited” message at the same time.
Ahhh that simply means that it isn't picking up sign/lane info where you are, which would make sense as you are probably in a parking lot or neighborhood
